V6 Third in a 4Cyl. axle
Old 02-21-2008, 06:51 PM
ttr125mar's Avatar
Can a V6 third be put in a 4 Cyl. axle? I was reading that a couple guys put 4Cyl. third in a V6 axle.
Thanks,
Mario
Old 02-21-2008, 07:09 PM
Elvota's Avatar
Yes.
V6 is 4 pinion, 4cyl is a 2 pinion. So, V6 is stronger. Everything else such as bolt patterns and axles are the same.
This is assuming 4WD to 4WD or IFS to IFS.
At least... I think that's right.
drew303's Avatar
yes !
The thirds are interchangeable. The 'axles' are the same.
Old 02-21-2008, 08:14 PM
Matt16's Avatar
What about the ratios. I heard that a 4 cyl. has a 4.11 to the V6's 4.10. Is this true across the board with all the V6 thirds behind close, but not quite the same?
Old 02-21-2008, 08:21 PM
Elvota's Avatar
Well... ratios need to match for everything to work.
Scroll down here, I saw only 4.10's (no 4.11's):
It's got a ton of factory ratios from different vehicles. Should answer what was available with what and when.
alexcarey
10-14-2015 06:05 PM
I8URSVT
10-05-2015 07:23 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: V6 Third in a 4Cyl. axle
