turbo questions
turbo questions
well my buddys G/F has a 87 turbo auto she let it run out of oil yesterday and the motor is seized up this truck did not leak oil too bad but the turbo would suck a quart down every 2 weeks or so
so now he is looking at having the motor rebuilt and removing the turbo altogether will what will he need to do to leave the turbo out from the rebuild
dose he nee a new ECU?
will he need diffrent piston heads or are the turbo ones ok to run?
any ideas are welcome
thanks
thanks
The ECU is very different
here's the basic run down of stuff you will need to change:
Pistons
head
injectors
Injector plugs
ECU
exhaust manifold
Intake piping
emissions junk
Rad(or simply soder the turbo pipe closed/off)
You will also need to block off the oil feed.
Pistons
head
injectors
Injector plugs
ECU
exhaust manifold
Intake piping
emissions junk
well looks like he is going to get the rebuild kit from engnbldr and has a guy who will do the bottom end work then he will put the head back on and everything else.
good thing is he has a second turbo motor so he is going to have the work done on it and then pull the one in the runner and swap them, the rings are blown on the second one as well.
ocala, i just picked up an 88 turbo runner and im looking to rebuild the entire engine and possibly upgrade to the ct26 or t3/t4. im looking for any kind of links and info that people may have , pictures ect.
ChiefTetlow
08-10-2015 04:19 AM
