Truck Groan on startup
Old 06-13-2011, 07:29 AM
mojo4x420's Avatar
My truck makes a strange noise on startup sometime. You can see it at 0:11 of this video.
http://dev.mantlegames.com/rob/truck_groan.flv
Any ideas? It started during the winter I believe. It only does it when it's cold and it usually doesn't last more then a few seconds (rarely it'll go for 30 seconds).
I bought a remanufactured engine and my timing chain guides broke after < 80,000km. I just replaced them, chain and headgasket. This video is post replacement and it's still making the same sound. Last year when the noise started, I replaced the waterpump and distributor.
Truck is driving better then ever though on it's short test drives so far, but I'm worried about driving it until I figure out what's wrong.
If you can't see the video, try installing
http://www.videolan.org/vlc/
Thanks!
Old 06-13-2011, 08:01 PM
drmix's Avatar
Can you tell which side of the motor its coming from? Could it be the clutch fan?
Old 06-14-2011, 02:44 AM
TNRabbit's Avatar
My best guess is a bearing is on it's way out. Fan, alternator, power steering, A/C compressor, etc.
duckhead
170
11-13-2017 06:07 AM
MadMax48
07-03-2015 08:26 AM
shadowbirdie
06-24-2015 03:54 PM
Quick Reply: Truck Groan on startup
