Truck died at Buffalo Wild wings!
Old 03-08-2008, 06:02 AM
Firebb15's Avatar
So i come out of BWW and find my truck won't start as im rolling out of the take out only parking spot. It did this last week for a few minutes at work, i thought i had water in my gas. Well it didnt restart this time, so with a few shots of starting fluid and some pushing i got it to the back of the parking lot in under 20 degree weather. So do 1994 yotas have fuel pump cut off switches? Our 94 explorer popped it's switch while sitting at a red light, thought i blew the fuel pump on that one. I accept the fact that the pump finally died being 14 yrs old and a lil over 206K. I'll check the fuse when i bring my dolly today. Is there a relay I can check also? Thanks for the help, Brian
Old 03-08-2008, 07:32 AM
MMA_Alex's Avatar
I dont think they have intertia switches. Truck just needs more hotsauce...
Old 03-08-2008, 07:41 AM
bigt's Avatar
how are the wings there i seen the commercial and i was gonna go over to the states to buffalo just to check them out....
Old 03-08-2008, 08:08 AM
881stGenRunner's Avatar
pull the engine codes by jumping the TE1 and E1 (i think) terminals under the hood and turning your key to the on position. count the number of flashes and see what you code is.
Im going say you have a bad ignitor because my did the same dang thing on me. turned out to be a bad ignitor. It would just crank and crank and crank, but no spark.
This code is 14 if you pull the codes.
Old 03-08-2008, 08:15 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
There is a fuel pump relay switch (aka "circuit opening relay") behind the pass. side kickpanel and speaker. You have to pull the glove box and speaker to get to it.....I believe.
Old 03-08-2008, 10:14 AM
MMA_Alex's Avatar
If you're jumping across to buffalo go to the anchor bar, where they were invented.
BWW is a chain founded in the midwest
Old 03-08-2008, 10:23 AM
bigt's Avatar
ive been to the anchor... the williow, clanceys, gagster ,good fellas.the cove and a bunch of others but i loves me some suicide wings!
Old 03-08-2008, 04:26 PM
Firebb15's Avatar
Yes BBW are fantastic...and i HAVE spark, it will fire on starter fluid. Im going to look into the relay or a fuse...if everything is fine, im buying a rolled sr5 pickup tomorrow so looks like im swappin fuel pumps too. Thanks
Old 03-08-2008, 04:28 PM
MMA_Alex's Avatar
if you have spark, and it'll run on ether its a fuel issue. crank it over some, and pull a plug and see if its wet.
that way you can see if you have any fuel going into the cyls
Old 03-08-2008, 04:41 PM
BRreddog's Avatar
Check the rubber accordian from the AFM to the TB. If it's cracked theres no fuel flow. A duct tape fix will get you home.
BWW is good !!
puffin04
07-10-2015 09:17 PM
MadMax48
07-03-2015 08:26 AM
sonic concepts
07-01-2015 02:33 PM
ibayne
06-26-2015 06:30 AM
Outsane
06-24-2015 05:52 PM
Quick Reply: Truck died at Buffalo Wild wings!
