Transmission Fluid Change
Old 06-01-2014, 08:55 PM
92-4runner4x4's Avatar
hey Guys, I've got a Question! I'm flushing all the fluid outta my transmission and Transfer Case. I drained all the Transmission Fluid and Gear Oil, Pulled the tranny Pan down and cleaned it all out! How many Quarts of Tranny Fluid do i need? Im hearing 8 but i'm also reading if its completly empty it takes 10.9 Quarts? Also does the transfer case have a Filter as well?
Old 06-02-2014, 09:03 AM
scope103's Avatar
It depends on which transmission you have.
Old 06-02-2014, 09:31 AM
JasonYota's Avatar
Taking a guess he has an auto, since he asked if the t-case has a filter also.
Old 06-02-2014, 09:34 AM
yes sorry it's auto
Old 06-02-2014, 09:37 AM
millball's Avatar
Cases of 12 quarts of Dextron III can be bought on Amazon for less that $40.
Old 06-02-2014, 09:39 AM
JasonYota's Avatar
It will be the lower amount for a drain and refill. The higher number is after a rebuild when there isn't any left in the trans. To my knowledge there is not a filter in the transfer case like in the transmission.
Old 06-02-2014, 12:28 PM
scope103's Avatar
Originally Posted by 92-4runner4x4
yes sorry it's auto
Sigh ....
Well, that narrows it down to four different automatic transmissions used on pickups/4runners. The "drain and refill" capacities are between 1.6 and 4.8 US Quarts. (I have no idea where you are "reading", but the higher number is for a completely empty transmission, which you cannot do just by removing the pan.)
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Transmission Fluid Change
