Transfer case lift? Your ideas.
Old 09-25-2010, 08:40 PM
94toy4x4fever's Avatar
Hey guys I got my 7mge swap done in my toyota pickup. Im having a issue with the intake hitting the break booster. I did dent the booster about a 1/4 inch but dident want to beat it up to much. What do you guys think about building a spacer to lift the transfer case a inch or two so it will push the engine forward just a little bit to make the intake clear the booster? See when using the 5mge motor mounts ( engine side) it puts everthing at a 10 degree angle. Is there any affects of lifting the transfer case enought to gain some clearence?
Old 09-25-2010, 10:15 PM
muddpigg's Avatar
Why not a drive train lift. Your sig says 2" body lift. 4crawler sales the motor mount blocks. Could even go flat belly.
Old 09-26-2010, 12:46 AM
I to noticed that 4crawler sales a transfer case lift. I had somthing like that in mind to build! I dont need much. Just wondering if it was a good or bad idea
Old 10-03-2010, 08:27 PM
I lifted the transfer case with a 1 1/4 thick block in between the mount and the crossmember! Worked like a charm.
Old 10-03-2010, 08:30 PM
Fossilized
Staff
dropzone's Avatar
block of what?
How is your driveshaft angle's now? seems like a bit much...but if it works for you..cool
Old 10-03-2010, 08:58 PM
Block of steel. It isent much drive lines dont bind at all. With the 5mge motor mounts it puts the drive train at a negitive angle of 10* so a little bit of lift on the transfer case is ideal when you got a 7mge engine swap!
4x4-runner
12-27-2016 01:58 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
ViperTT
08-14-2015 05:27 AM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Transfer case lift? Your ideas.
