trans removal question
Old Nov 11, 2007 | 03:20 PM
gametom's Avatar
ok so I'm trying to replace the clutch on my 91 runner 22re 4x4. and I'm lowering the trans out but it's getting caught on the transfer case shift lever in back and the spline in front. do i take the transfer case shift lever off (how) or is there something I'm missing
Thanks
Old Nov 11, 2007 | 03:25 PM
mt_goat's Avatar
Yes, take the shift lever out. There is a C-clip that holds it in place, lift up the boot and you'll see it. Going back on you have to compress the spring a little to get it back on. As soon as you take out the shifter stuff a clean rag into the hole to keep you from dropping anything into the t-case.
Old Nov 11, 2007 | 05:30 PM
gametom's Avatar
Thank you mt goat
Old Nov 15, 2007 | 08:21 PM
gametom's Avatar
ok now i can put it in but it wont shift between anything like it's in sideways any ideas
thanks
Old Nov 15, 2007 | 08:25 PM
CRONK4X's Avatar
you put the shifter in backwards flip it 180 degrees
Old Nov 16, 2007 | 05:43 AM
mt_goat's Avatar
That or you just got the shifter tip into the wrong slot (hole). I ususally test it out before putting the clip back on.
kazuya2416
Apr 5, 2024 02:17 AM
coffey50
Jul 28, 2015 10:55 AM
the1998sr5
Jul 16, 2015 06:20 AM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
