tranny bolts
Old 08-25-2009, 10:11 AM
baseballchamp157's Avatar
tranny bolts
ok so i use to have a 85 pickup with the 22re and the tranny bolts werent that bad to get out but now i have a 90pickup with the 3.0 and i cant even imagine how ima get the top tranny bolts.... so does anyone have any suggestion on how to get the top bolts? cause i just blew my 3.0 muddin, luckly i already head a backup motor to put in but like i said i need them tranny bolts off.
Old 08-25-2009, 10:13 AM
malteserunner's Avatar
Long extension and a swivel socket works for me. Good luck.
Old 08-25-2009, 10:16 AM
Tubbyfatty's Avatar
The top 2 big bolts are easy, 3 ft extension and a maybe a swivle. Thats what i did when i did my clutch. I got em at the t case.
Old 08-25-2009, 10:26 AM
yea but do yall have body lifts cause this truck dont and there aint no room at all
Old 08-25-2009, 10:37 AM
I didn't have a body lift one either my 91 or 92 with 3.0's, and I had no problems getting those bolts out.
Old 08-25-2009, 10:44 AM
92silverrunner's Avatar
Ive pulled a few 3.0 motors and a 3ft extension with a swivel and 17mm shallow socket works well
Old 08-25-2009, 11:25 AM
so is ther only 2 17mm bolts on top because i have the 4 bottom bolts that are extremely easy to get to. and of course the starter bolts, and the 2 other 14mm bolts. but is there any other?
Old 08-25-2009, 05:43 PM
bugs1961's Avatar
The FSM shows 12 bolts total, including the starter. Take the rear cross member and rear trans mount off per the FSM and lower the engine on a jack. This will give you plenty of room.
Old 08-25-2009, 06:15 PM
Tubbyfatty's Avatar
I just took off the 12 bolts and dropped the x member, i didnt take off the rear mount. It worked out fine.
Oh yea, the center of the tranny and x case is right in front of the x member. Its the perfect balance spot haha.
Old 08-25-2009, 06:25 PM
abecedarian's Avatar
these come in handy too:
Old 08-28-2009, 09:30 AM
alright so ive got the tranny bolts out. all 12. instead of takin out the exhuast bolts i just cut it so i can go ahead and take the motor out quik. But i still cant seem to pull the motor out. even bent one of the hangers that come from the head. any idea guys?
Old 08-28-2009, 07:37 PM
its been 10hrs and no response. thanx yall
Old 08-28-2009, 07:57 PM
Tubbyfatty's Avatar
When i was pulling my tranny, i could only pull it straight back about 2 inches then i realized the t case shifter housing was getting caught on the shifter plate. So i bent it up a little bit and then dropped the back.
Can you at least pull it back an inch or so?
Old 08-28-2009, 11:22 PM
turborich's Avatar
Did you lift the engine up & pull it forward so it clears the trans? If so then something has still gotta be attached.
Old 08-29-2009, 06:49 AM
I pulled up and out. with a tractor. ive triple checked the tranny bolts. there is none. what else could be holdin it? and TubbyFatty im pullin a motor not the tranny..sorry if i didnt clear that up
pplusent
09-18-2018 10:02 PM
squiggypowell
08-19-2015 03:07 PM
agrout
08-13-2015 06:12 PM
yourrealdad
07-21-2015 11:13 AM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: tranny bolts
