torshion bars
Old 06-12-2007, 08:53 PM
90inworks's Avatar
torshion bars
how do i crank them up im geting blocks for the rear tomarrow and need some one to post up some pics showing me how to do this?
Old 06-12-2007, 08:57 PM
deathrunner's Avatar
First, try searching. That will give you a detailed answer.
But, essentially, you want to jack the front end up until the tires come off the ground. DON'T ADJUST THEM ON THE GROUND.
Spray penetarnt on the adjusting bolts.
I believe some of the older trucks have a lock nut, you should be ok.
Drop it back down and drive it around. Check and repeat if necessary. GET AN ALIGNMENT.
Old 06-12-2007, 08:59 PM
881stGenRunner's Avatar
http://personal.utulsa.edu/~nathan-b...29torsionb.pdf
Old 06-12-2007, 09:04 PM
90inworks's Avatar
i dont know wat bolt to adjust is the thing sry for not searching i can never seem to get what im asking
Old 06-12-2007, 09:06 PM
http://toyota.off-road.com/toyota/ar....jsp?id=398514
https://www.yotatech.com/forums/show...bar+adjustment
5 second search. Give it a try. It really works.
I typed in "Torsion bar adjustment"
Old 06-12-2007, 09:16 PM
90inworks's Avatar
sounds good that first link gave me a good idear im gonna her a try
thanks yall
Old 06-12-2007, 09:20 PM
Jay351's Avatar
Seriously get an alingment ASAP after messing with your torsion bars.
And I would avoid cranking the bars more then about 1-1.5"
Old 06-12-2007, 09:21 PM
07sbock's Avatar
Spray The Hell Out Of The Adjusting Nuts With Penetrating Oil!!! I Broke One...it Sucks. The Dealer Dosent Stock Them.
Old 06-13-2007, 08:19 PM
90inworks's Avatar
well i got the lift blocks in today and tried to crank my tosion bars but couldnt figure it out so no luck on the front.
Old 06-13-2007, 09:48 PM
Seriously, if you couldn't figure out how to crank up the torsion bars.....please do not put the blocks in by yourself.
Old 06-13-2007, 11:07 PM
Corbit's Avatar
Just across the pond
Hey fellow Yota freak. I'm just about 20 minutes from Sedro , PM me , I got some time this week.
ladybugRC
458
08-21-2020 10:41 AM
choppe777
05-16-2016 08:00 AM
A2theK
10-14-2015 07:10 AM
Obmi
10-04-2015 11:30 AM
mdh
09-15-2015 12:12 AM
Quick Reply: torshion bars
