timing issues
Old 02-01-2010, 08:24 PM
kdogy313's Avatar
timing issues
I just rebuilt the top end of my motor and the timing seems off. I have tried the distributor and that doesnt seem to quite do the job. is there a sure fire way to tell if it is the timing belt?
Old 02-01-2010, 08:26 PM
Staff
DeathCougar's Avatar
Just make sure you have the timing marks correct. Ie, set your mechanical timing first. Then, move on the distributor timing. Its not uncommon for someone to get the distributor in one tooth off.
With the crank at top dead center (aka 0 on the timing cover mark) your cam hash marks should be right on, and the belt will go right on as well.
Old 02-01-2010, 08:57 PM
RMA
RMA's Avatar
did your timing belt have marks on it or was it one with out marks.
its pretty easy to think you have it lined up right but not really have it right.
bigjstang
08-25-2021 12:41 AM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: timing issues
