timing chain replacement no start (kinda) help!!
Old 01-31-2012, 02:19 PM
goat's Avatar
so l just replaced the timing chain
(and cover and water pump guides)
put everythign back together
and it wont start
it turns
and catches
but dies immediatly
seemes like it could be fuel related
btu l didn't do any thing to fuel system?
please help
asap
thanks
goat
Old 01-31-2012, 02:23 PM
goat's Avatar
it's a 22RE
92
Old 01-31-2012, 02:30 PM
snobdds's Avatar
I would say with 99% of these..."I just did the timing chain and it won't start" theads, and there is a lot of them, it due to the timing being off. Double check your cam timing and then make sure your ignitin timing is correct. I bet your 180* off.
Search, there is plenty on the topic, and it will be better for you to read up on the topic and then ask your question.
Old 01-31-2012, 03:00 PM
goat's Avatar
the bright links are on the dimples
the crankshaft notch was at 0
the square raised bump on the camshaft was on top
the dizzy is in right
it starts right up
runs real smooth sounds good
(no coughing backfiring roughness)
but dies after 5-10 seconds
the starts right up again if l try
seems to me that the cold start injector is firing
and the rest aren't
l've triple checked that everything is plugged in
and trouble shooting pointers or thoughts would be most usefull
searching around some one with the identical problem had the injector ground disconnected
cant find any thign that tells me where that is
thoughts pics pointers?
thanks goat
Old 01-31-2012, 03:20 PM
Beaniam's Avatar
you have the boot from the throttle body to the afm hooked up right?
Old 01-31-2012, 03:31 PM
goat's Avatar
yep
was just about to search around to learn about the afm
goat
Old 01-31-2012, 03:38 PM
goat's Avatar
turns out the connector to the afm wasn't making good contact
now it starts right up
thanks
goat
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
Badger62811
06-26-2015 09:26 PM
Taz22R
06-21-2015 04:44 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: timing chain replacement no start (kinda) help!!
