Is there a 4wd light?
Old Oct 7, 2006 | 03:53 PM
whitetaco02's Avatar
I have an 88 4runner, SR5, automatic and was wondering if there was a light that was supposed to come on when I put it in 4wd. When I first got it a few months ago, I put it in 4wd and no light came on but I know that the 4wd works due to difference in driving, turning, etc.... is there supposed to be a light that comes on in the dash when the 4wd is engaged? if so, what do I need to do in order to make sure everything really is working properly? is there a bulb that i can replace to get the light to come on? thanks so much!!
Old Oct 7, 2006 | 04:04 PM
Elton's Avatar
yes there should be a light sounds like the bulb is burned out
Old Oct 7, 2006 | 04:09 PM
EWAYota's Avatar
I believe theres a wire connector on the transfer case that runs to the guage. If that is unplugged, the light will not turn on. I'd check that first before tearing into your dash to check for a burnt bulb.
Old Oct 7, 2006 | 04:20 PM
swerks's Avatar
I have a 86 4runner and no light comes on and I do not see anything mentioned in the owners manual ?????
Old Oct 7, 2006 | 05:29 PM
881stGenRunner's Avatar
From an 88 runner
Old Oct 7, 2006 | 05:31 PM
waskillywabbit's Avatar
Yep, all 1st gen 4Runners were 4WD and they all have the 4WD light on the dash.
Old Oct 7, 2006 | 05:38 PM
mt_goat's Avatar
The wires sometimes get broken where they come out of the sensor/switch on the transfer case.
Old Oct 7, 2006 | 07:34 PM
ok, thanks
Old Oct 7, 2006 | 07:36 PM
any idea of where to exactly look for that? pics, write-up?
really???!!! mmmmm
making me think now???
Old Oct 7, 2006 | 07:37 PM
Originally Posted by 881stGenRunner
From an 88 runner
thank you for that!! any help would be greatly appreciated on what I can exactly do to pinpoint this. pics, etc...
Old Oct 7, 2006 | 07:40 PM
thanks man!! I need to do some researching tomorrow then. i need some help because I want this fixed. i know it comes on because it drives differently when i have it in 4wd. can somebody please point me in the right direction? what exactly do i need to look for? and thank you all so much for the replies!!
Old Oct 7, 2006 | 07:47 PM
EWAYota's Avatar
Just crawl under the truck and look at the transfer case, both sides and if you can, look on top as much as possible. On mine it was on the drivers side if I remember correctly. Its pretty simple, just look around and check for a wire connector dangling around, might be tucked up on top of the transfer case or maybe as simple as its right next to where it would plug in. If you find a connector thats plugged in on the transfer case, trace the wire as far as you can and make sure it's not damaged or unplug it and see if it's filled with dirt or anything. I'd post pics, but I won't be able to get to until tomorrow evening.
Old Oct 7, 2006 | 07:49 PM
ok, i will definitely look tomorrow after church tomorrow. i will look and if i have luck i will post back. if not, i would appreciate some pics if it isn't too much trouble. thanks
Old Oct 8, 2006 | 02:56 AM
swerks's Avatar
I have the digital dash that came with the turbo and I can not even find where the light is suposed to be ???
Old Oct 8, 2006 | 09:25 AM
GrimReaper's Avatar
There are TWO connections to check under the truck. One near the shifter on the case and one up by the starter. Up by the starter there will be a couple different plugs. ONE MAY NOT BE USED. The Main harness on the motor has provisions for both auto and manual. The manual only has the revers light connection and the transfer case indicator.
Old Oct 8, 2006 | 04:34 PM
i looked everywhere and saw a few wires but they all look like they are connected. i saw one spot where it looks like some wires were taped with electrical tape. that might be the problem but I am not sure. it is very hard to get to. should i even worry about it? is this a problem that I need to fix or can i just forget about it?
Old Oct 8, 2006 | 05:43 PM
GrimReaper's Avatar
Where at in GA are you?
Old Oct 8, 2006 | 05:47 PM
GrimReaper's Avatar
You know there is another connection to be checked.
The light wires is in with the FI harness. If the motor or head has been pulled its possible that they unplugged the harness in the passenger side kick panel at the computer and didn't get it plugged back in there.
Old Oct 9, 2006 | 07:23 AM
warner robins
