Is there a 4wd light?
Old Oct 9, 2006 | 07:23 AM
whitetaco02's Avatar
Originally Posted by GrimReaper
You know there is another connection to be checked.
The light wires is in with the FI harness. If the motor or head has been pulled its possible that they unplugged the harness in the passenger side kick panel at the computer and didn't get it plugged back in there.
the motor has been pulled. any pics on what wire that may be?
Old Oct 9, 2006 | 07:27 AM
881stGenRunner's Avatar
hmm im in newnan.
Old Oct 9, 2006 | 07:29 AM
amgraham's Avatar
If 4wd works I wouldn't sweat the light. All it really tells you is that you shifted the t-case into 4wd, which you would obviously know. I guess it's more of a reminder to shift out of 4wd when you get back to dry road.
Some other trucks, like Chevys for example, use the light as an indicator the the hubs are locked in. If the hubs don't lock, the light stays off. This is not the case with our trucks (at least with manual hubs. I don't know if it's different with auto hubs..).
Old Oct 9, 2006 | 09:59 AM
mt_goat's Avatar
In this pic you can see the sender for the light on my Marlin Crawler (2 blue wires):
The first sender Marlin sent me on this crawler one wire was almost broken off right where it starts at the sender.
Old Oct 9, 2006 | 12:27 PM
  #25
yeah, i saw something similar to that on mine but it is just so hard to get to without being on a lift. i may drive by my mechanic to see if he can check it out for me. thanks for the pics!!
Old Oct 9, 2006 | 04:27 PM
  #26
GrimReaper's Avatar
Uhhh I don't have a pic. Pull the three screws that hold the kick panel in. The eCM will be bolted in under it. Remove the three bolts that hold that in and you will see all the connectors. There may be one or two that don't have plugs but look to see if any that are loose have a mate.
If you were close I would have you swing by one Saturday when I am around and we could take a look at it.
I get to Warner Robins every couple weeks for work but I'm wide open when I am there. Not much time to crawl under a truck. If you don't have it sorted out I will be down there possibly next week. You have to buy my lunch at Ginji though if I get to tinkering on your truck. LOL.
Old Oct 9, 2006 | 05:04 PM
  #27
HAHAHAHAHA LOL that place is good man. my wife and I eat there all the time. thanks for your replies but i may just let it go. not sure about all the wiring stuff and would hate to mess something up. l0l
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
