temp. gauge needle drops when fan is turned on?
Old 09-14-2009, 08:49 AM
Silverunner's Avatar
When the truck is idling at normal operating temperature the needle stays in the middle like it should. But when I turn the fan switch on the needle drops down to 0, while the engine continues to run normal temps. I've shorted out the sending unit wire and this caused the needle to rise then I turn the switch on and the needle stays in same position.
I've replaced the sending unit and fixed the wire connector but the needle still drops to 0?
I'm not sure where else to look right now? Where are the grounds located maybe I missed one?
Thanks
Old 06-12-2012, 10:00 PM
griff.8604's Avatar
anybody figure this out yet mine is doing the same thing
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
gary4runner
09-24-2015 12:53 AM
coryc85
09-09-2015 06:24 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: temp. gauge needle drops when fan is turned on?
