Teeny Tiny Springs in rear diff.....
Old 02-11-2009, 09:39 AM
kfergiez's Avatar
So the other day, i was flushing my transmission and diffs. the front diff fluid was very clean. the tranny fluid was also very clean. the rear diff fluid was slightly dirty, but i found about 5 or six of these tiny springs. i'm talking smaller than the springs you find in a clicky-top pen. anyhow, they were attached to the drain plug magnet. now i bought this thing used, and to my knowledge it does not have any lockers in it, however that is the only thing that i can think of that would have those small springs. any thoughts?.
92 Runner, V6, Manual 5,
Old 02-11-2009, 09:42 AM
mt_goat's Avatar
Wow, never heard of that happening.
Old 02-11-2009, 09:46 AM
mt_goat's Avatar
Were they broken on the ends, like pieces of one long spring broken up or were they all the same length? Maybe a seal came apart, they sometimes have a long circular spring around the inside.
Old 02-11-2009, 09:57 AM
Junkers88's Avatar
X2. I know that some seals have a very very small "spring" in them. I don't know if axle seals do or not but that would be my best guess.
Old 02-11-2009, 10:01 AM
abecedarian's Avatar
I agree with the others about a seal being the source: sounds too small to be of use in a locker... now which seal is another issue.
Most shaft seals have a spring wrapped around inside the lip of the seal to help pull the seal tight around the shaft. If someone messed up installing the shaft or seal, the spring may've been popped out and chewed a bit by the gears before they got to the magnet.
Old 02-11-2009, 10:29 AM
cormel's Avatar
I bet the previous owner is playing a hoax on you...put them in there to confuse everyone
Old 02-11-2009, 11:20 AM
OutlawMike's Avatar
x3 on the axle shaft seals. The outboard seals on each axle have a circular spring that preloads the seal lip against the shaft. I would bet that someone had the axles out and when they put them back in they popped one or both of them off.
You may want to pull your axles to verify that is what it is and to replace the seal so that you do not get a leak out at the brakes.
It is amazing on what a magnet will pick up.
Old 02-11-2009, 11:26 AM
mastacox's Avatar
There is also a spring like that in the pinion seal, for what its worth. One way or another, it sounds like you've got a bad seal somewhere.
Old 02-11-2009, 12:32 PM
Matt16's Avatar
Can't remember seeing a seal with a tiny spring in there, are they a bit like the springs used to clamp on the boot on some TREs?
Here's a locker spring, maybe the last owner blew up his locker and never got all the bits out:
Haha, I though about putting a valve in the oil pan to confuse the next person who does the timing chain.
Old 02-11-2009, 01:09 PM
87LVRunner's Avatar
That's just mean!!, I like it!
x10 on the seal spring. Prolly an inner shaft seal grenaded at some time. Have the PO's number? Maybe he could entertain ya.
Old 02-11-2009, 01:40 PM
Yeah Matt16, a lot of shaft seals have a spring like the tie rod end boots, but they're inside, around the lip that seals against the shaft.
Old 02-11-2009, 04:14 PM
kfergiez's Avatar
you guys are geniuses. i never thought of a seal. i bet that's it. it's not leaking however.
Old 02-11-2009, 06:10 PM
mt_goat's Avatar
Yes, you're right
Old 02-11-2009, 06:14 PM
figures 'mt goat' would accept kudos first.
everyone realizes we have to sacrifice a goat when enlightenment is attained, no?
Old 02-12-2009, 05:18 AM
mt_goat's Avatar
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
terminator
07-27-2015 07:13 PM
yourrealdad
07-21-2015 11:13 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Teeny Tiny Springs in rear diff.....
