tech question
tech question
got a question yesterday i was installing a cd player in my 94 pick up and i had the radio on for about 3 hours so i think i might have killed the batt but when i have ignition turned to the on position its showing the battery has more than half energy on the gauges but when i try to crnk it over it make a wierd noise but dont turn over. i also disconnected the wire that runs from the positive side of the batt to the fuse box then i re connected it, when i jump start the truck it starts no problem. anyone got any suggestions?
Weak battery. Assuming you were running ONLY the deck (no amps, etc) a good battery should lat a lot longer than three hours and still crank the engine. The fact that it jumped easy screams weak battery as well. To confirm, have it tested, but I have a feeling you're due for a new one.
i did jump it and try to start it but it didnt start after i shut it off and the lady who sold it to me said it was a new batt. and why is my gauge saying that i have more than half a charge?
Since the gauge goes to 18, half a charge is only 9 volts
If you battery is at anything lower than 12 volts, you have a problem.
And define "New battery" Brand new she got from a store with paperwork to prove? Or new to the truck, and she pulled it from her 1946 Buick she had sitting in the weeds for 10 years. I never trust anyone who says "new parts installed" unless they have receipts to prove it.
Jcrawl94
10
10-24-2015 04:34 PM
Koolbananass
08-12-2015 01:59 AM
landrunner
08-05-2015 09:18 PM
