steering shaft
Old 06-18-2008, 12:41 PM
sleaz22xx's Avatar
steering shaft
I removed a 3 inch body lift that PO had installed on my 94 runner and im now having allot of stiffness in the steering shaft
I had to remove the steering shaft extension that came with the lift, which took allot of man handling to get out, now im getting the stiffness problem in the steering column, What could be cuase this to bind?
Is it possible that I damaged the small u joints in the steering shaft itself?
any advice is appreciated!
Old 06-18-2008, 01:04 PM
TOYOTA 1's Avatar
some body lifts come with a spacer that goes where the shaft housing bolts to the floor?
maybe you have one in yours??
just a thought!
Old 06-18-2008, 01:12 PM
abecedarian's Avatar
some body lifts come with a different firewall plate that works with the steeper steering angle caused by the lift. if the kit from the truck had that, you'd be binding the bearing in the plate when you remove the lift.
(I think that's what TOYOTA 1) is referring to.
You'll eventually stress the couplers in the steering shaft (the flexible rubber/cloth looking part) and you don't want that part to break.
You'd have to get one from a salvage yard or the dealer.
Old 06-18-2008, 01:15 PM
TOYOTA 1's Avatar
hehe. thats what i was talking about lol
Old 06-18-2008, 01:17 PM
TOYOTA 1's Avatar
i forgot this was yota tech not yota close enough. lol
Old 06-18-2008, 01:23 PM
lol. no harm, no foul, no?
my wife likes to tell people I'm the inventor of scrabble because I tend to be somewhat retentive and precise about things. I tell her I didn't invent scrabble- I just told the guy how to spell the name.
Old 06-18-2008, 01:25 PM
sleaz22xx's Avatar
Right on you guys got it right on the money, THANKS A TON this had me stumped for the last couple days
Old 06-18-2008, 01:29 PM
yay!
you can double check the steering shaft firewall bushing by unbolting it from the firewall and checking that the drag / resistance is gone.
Hopefully, the lift kit didn't have an extended steering shaft as well....
Old 06-18-2008, 01:35 PM
TOYOTA 1's Avatar
no harm at all!
Old 06-18-2008, 02:25 PM
sleaz22xx's Avatar
the kit had a bolt on extension the was attached at the steering box output shaft, got that out just fine, once again thanks for the help
Jcrawl94
10
10-24-2015 04:34 PM
4x4-runner
08-30-2015 08:55 AM
CratesCruiser
08-23-2015 06:12 AM
4x4-runner
08-02-2015 09:24 AM
yoterr
07-24-2015 04:29 AM
Quick Reply: steering shaft
