steering gear question
Old Dec 17, 2007 | 12:14 PM
bodo4runner's Avatar
I have a 1989 4runner 22re 5 speed 4wd. At low speeds on rough road surfaces my 4runner bump,clunk…..left side
The steering gear will play,. if I push it up and down.Is it normal? (look photo).Also,no problem with idler arm,pitman arm,steering damper,tie rod end,ball joint,control arm bushing,stabilizer bar link,bushing,shock absorber etc...like a new
This is not a photo of my car.
IT'S NORMAL UP AND DOWN?????
Old Dec 18, 2007 | 06:39 AM
It's Normal Up And Down?????
Old Dec 18, 2007 | 08:13 AM
GSGALLANT's Avatar
I don't have the same truck or steering setup, but I would say any up down play there would not be normal.
Old Dec 18, 2007 | 10:51 AM
elripster's Avatar
That would be bad. Do you have excessive play in the steering wheel?
Frank
Old Dec 19, 2007 | 09:16 AM
well, steering wheel freeplay approsimate 30 mm (1.18 in.)
should I change the steering gear a new steering???...
http://www.rockauto.com/catalog/x,ca...6,partGroup,26
Thanks!
XtraCab
Apr 12, 2020 05:25 AM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
voiddweller
Jul 15, 2015 03:56 PM
Jnkml
Jul 6, 2015 01:20 PM
