Starting problems
Old 11-05-2007, 10:48 AM
jfrizman's Avatar
Starting problems
The other day I went to start my 86 4runner and all it did was click. I tried several times. I ended up having to crawl underneath and had to take the little wire off the starter and cross the battery wire to the litle wire treminal on the starter. My first thought was the solenoid on the starter was out. But after thinking it through i am starting to question myself. If I am not mistaken the little wire on the solenoid ont he starter just gives a little juice to the solenoid to trip it and let the contacts tought to start the motor. But if all I did was take the little wire off and cross the teminals directly from the battery than I was still using the solenoid. So maybe it is something else. Any ideas.
Old 11-05-2007, 10:52 AM
Jay351's Avatar
usually hearing just a click points towards the starter contacts. If you got a few hours and a few bucks you can replace them.
Old 11-05-2007, 10:59 AM
Flash319's Avatar
Sounds like a bad ground to me. Clean your battery posts and give it a try.
Old 11-05-2007, 11:09 AM
Spence1016's Avatar
x2 the starter contacts where down unevenly so sometimes the thing that spins gets caught on one. pretty easy to fix just find the right contact replacement kit.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Starting problems
