Starting issue (ignition??)
Ok so i have a new problem for you guys. I'm hoping its one that has already been diagnosed for someone else, but my searching revealed nothing.
On my 1990 3vze powered std pickup, i have a starting issue. It seems to only happen when i haven't driven the truck in a day or so. When i go to start it, i crank the key and i'll get a click... the first couple times it happened, i turned the key off, swore and eventually replaced the starter contacts (which were worn, but not that bad) I put it all back together and the same thing happened...
Tried it a few more times a few different ways and finally for some reason i held the key in the "crank" position. i got the first click as always, then a few seconds later another, then another until after about 15-20 seconds it started up...
Any ideas?
Any ideas?
check out www.4crawler.com for tips on repairing the ignition switch. check all your ground connections as well, could be that simple.
lee
lee
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
