SR5 Gauge Cluster
Old 05-30-2008, 06:17 PM
cosmo's Avatar
SR5 Gauge Cluster
I just swapped in an SR5 gauge cluster from a '92 4Runner into my '93.
Everything works fine, except that the tach reads about 1000-1500 RPM too low. I believe the cluster came from a V6 model. Is there any way to get it to read the correct rpm?
Old 05-30-2008, 07:06 PM
just a 22re's Avatar
yeah theres a away but im not sure i belive its something to do with something in the back of the gauge or trade it for a 22re cluster does the back of the cluster say 22re on the wire tape (the green thingy on the back) or does it say the v6 name
Old 05-30-2008, 07:21 PM
cosmo's Avatar
I'll check it and let you know.
thanks for the reply.
Old 05-31-2008, 06:06 PM
so cosmo whats you find?
Old 06-01-2008, 10:24 AM
cosmo's Avatar
I'm not finding any markings on the wire tape... any other identifiers?
It almost certainly is from a V6 since it reads too low.
Old 06-01-2008, 12:54 PM
i think the 22re ones said 22re on the ribbon tape on the back the big green thingy but yeah i think its from a v6
and sorry i dont know how to make it work for a 22re but i have read it somewhere where they did do it and it worked
Old 06-01-2008, 01:29 PM
rowdy235's Avatar
yeah Allan I think I read that too. But by the end of it I figured it would be so much harder, i'd just get a 4 cylinder one.
Old 06-01-2008, 01:44 PM
'884Runner's Avatar
Auto vs. Manual trans
I have considered a similar swap for my '88 22r-e 5 speed, and know where to get a tach from a 22r-e auto. Is there any reason this will not work?
Old 06-01-2008, 02:31 PM
foot0069's Avatar
Check this out
Jim
https://www.yotatech.com/forums/f116...ctures-102656/
Old 06-01-2008, 05:16 PM
cosmo's Avatar
so what do I do to take the cluster apart...
I assume I need to push the plastic tabs in and pull it apart.
Old 06-01-2008, 06:49 PM
cosmo's Avatar
still can't get the cluster apart...
Old 06-01-2008, 07:08 PM
ok to get the cluster apart if i remember right you have to take a flat head and push the clips out one at a time and unscrew the trip reset thingamabober and then you can unscrew the gauges from the back if you have a picture of this cluster i can show you by reposting your picture with the right way to remove it
Old 06-01-2008, 07:20 PM
cosmo's Avatar
finally figured it out. took everything apart and turned the adjustment screw forward, but now the tach doesn't work at all...
mussy01
12-13-2016 08:20 PM
gary4runner
09-24-2015 12:53 AM
highonpottery
08-25-2015 03:45 PM
mund1011
08-16-2015 07:10 AM
Esibnitsud
07-30-2015 08:21 PM
Quick Reply: SR5 Gauge Cluster
