Squealing noise from tranny area?
I'm getting a high pitch squealing when my 4runna idles and when I excelerate. It goes away when I put in the clutch and dies down in the higher gears. I'm leaning towards the pilot bearing but I wanted to know if anybody has had something similar to this happen to them .Thanx
Maybe speedo cable? They connect at the xfer case, and have been known to make high squeeling noises before going bad. ....disconnect the cable, drive around without your speedometer and see if you have the noise still.
Oh and yes, I currently have this problem...it is horrible but I found out how to fix it. I turn the radio up.
Yeah I turned mine up too but my consciousness said "You know the noise is still there, FIX IT" I don't think it's the speedo cable cause it's only a few months old from Toyota.
I just read a post with a similar problem and they said their input shaft and main shaft were toast. iijust want to know so I can plan my next move.
I just did the clutch when I put the 3.4 in. I may have tapped the pilot bearing too hard and damaged it. Just want to be sure before I pull the tranny and redo it. I may swap the throwout bearing also.
my tranny makes a squealing noise only when i first start it up in the cold
but I have an automatic, any suggestions as to what it is?
Athansinis
07-27-2015 08:38 AM
