Speedometer stopped working
Old 05-22-2008, 06:46 AM
stupid_mud_gremlins's Avatar
OK, so My speedometer just dropped to 0 on the weekend while I was on the highway. Cruise doesn't work either. Overdrive light flashes. And the check engine light comes on. I haven't run the codes for the check engine light yet. When I turn off the truck and then back on again, the CEL is out. Will it still give a code? The OD light flashes a 42 and 61 code when I run them. I believe that's for the combo unit and speed sensor in the trans. From what I have read when I did a search, it's looking like the speedo cable, but nobody says anything about a CEL. Would you guys agree with this diagnosis or is it something more complicated. As an after thought, I noticed a HUGE decrease in mileage. According to the GPS about 240 KM on a full tank. Possibly because the CEL is on?
Old 05-22-2008, 06:57 AM
Team420's Avatar
start pullin codes, the ecm will hold codes until u clear them
Old 05-22-2008, 07:29 AM
got a 42 on the CEL, vehicle speed sensor signal
Old 05-22-2008, 09:38 AM
abecedarian's Avatar
Can't be fer sure, but that speed sensor might be the problem. Don't quote me on that though.
Old 05-22-2008, 11:16 AM
Pulled the combo unit and backed n and out of the driveway, cable doesn't spin. Got the new cable for 23 bucks...but routing is a problem. Anybody got any advice on getting the cable through the stupid little port in the floorboards? It's only big enough for the casing of the cable to slide through...not the ends. How about alternate routing for the cable? Anyone have any good ideas?
Old 05-22-2008, 11:24 AM
Staff
DeathCougar's Avatar
I can be done, i did it on my 89 V6. IIRC, you have to pull it up through the floor, and install is the reverse.
its not too difficult, just a PITA to maneuver the line around in there. Take the time and do it right the first time, you dont want that thing hanging down and snagging on stuff.
Old 05-22-2008, 11:29 AM
ummm...hole is about 3/8"(JUST enough for the casing), connector at either end is 5/8" minimum...should have been clearer on that in the first place, sorry DC...
Old 05-22-2008, 11:43 AM
Staff
Well i dont have my truck here to look at, but I know it can be done like i said. I have done it before in both my 89, and my 90 (2nd gen) its time consuming, but not too tough once you figure it out.
Old 05-22-2008, 11:45 AM
iamsuperbleeder's Avatar
Old 05-22-2008, 12:19 PM
breknraj's Avatar
Before you get too far, check to make sure that you have the right speedo cable. There is are differences between the 4 cylinder and V6 cables, and I've never been able to find an after market cable for the V6, myself.
Without modifing the firewall mount on the cable, you will have to pull the E-brake cable from underneath the truck into the cab to replace the speedo cable. I love my truck, but I'd love to throttle the idiots that designed the set up!
Old 05-22-2008, 12:30 PM
Staff
Thats correct. I forgot about that step since I replaced my speedo and ebrake cables at the same time on my 89. oopsie
Old 05-22-2008, 06:10 PM
Got er done... Tin snips worked great, and just made a new half plate out of a piece of aluminum, and slipped on a rubber grommet. Stupid engineers.....
Old 05-22-2008, 06:17 PM
L33T35T 4Runner's Avatar
same here. just cut the plate in 1 spot, bend it up, put cable in there, bend plate back. done
Charecter1
11-06-2023 10:08 AM
icentropy
07-11-2015 07:21 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Speedometer stopped working
