speedo bounce
Old Sep 2, 2008 | 01:27 PM
nickmell's Avatar
speedo bounce
i have a 94 pickup and i noticed that every now and then the speedo and tach will jump and inch or two. any ideas?
Old Sep 2, 2008 | 02:10 PM
tc's Avatar
tc
My speedo would bounce, turns out the VSS wasn't in tight enough.
Not sure about the tach though - my first guess would be a bad ground.
Old Sep 2, 2008 | 02:15 PM
Jay351's Avatar
My speedo bounces around a little... I just chocked it up to the old cable system...
Old Sep 2, 2008 | 02:59 PM
lftd_86_yota's Avatar
i was just so happy this was not a link to a video
Old Sep 2, 2008 | 03:09 PM
bigtrucknwheels's Avatar
at 60-70, my speedo in my truck bounces +/-5 MPH on a bad day. some days only about 1 MPH. mine is an old cable driven speedo though. with a VSS I would say its loose.
Old Sep 2, 2008 | 03:18 PM
stormin94's Avatar
If I turn the key off real slow, the tach jumps to about 3,000 RPM. Or if I have the stereo up too loud, the speedo jumps a small bit.
Old Sep 2, 2008 | 03:23 PM
abecedarian's Avatar
too bad this is a serious thread
Old Sep 2, 2008 | 04:26 PM
Jay351's Avatar
Screw you Abe
Old Sep 2, 2008 | 06:27 PM
Screw you Abe
not after hearing about you chocking your speedo
Old Sep 2, 2008 | 06:53 PM
Jay351's Avatar
ooooooooooohhhhhhhhhhhhhhhhh
Old Sep 2, 2008 | 06:56 PM
how do you chock up to old cables anyways? is that some sort of pulley / block setup or something that keeps your speedo stable?
Old Sep 2, 2008 | 08:38 PM
space-junk's Avatar
nice one abe... on a side note, mine jumps too... i just figure that if it says im goin between 63 & 67 im good for the freeway...
but it could also be that you just need to grease the cable...
Old Sep 2, 2008 | 09:07 PM
if it's a cable operated speedo, then maybe the cable needs lubed.
if not, it could be the speed sensor, wiring, grounds, the gauge... who knows without testing it all?
and thanks.
Dieselmann
Feb 19, 2019 02:57 AM
Marley2984
Dec 6, 2015 05:19 AM
Davebarbier
Nov 3, 2015 03:28 PM
charlie_fong
Sep 27, 2015 10:06 PM
83
Sep 27, 2015 04:13 PM
