speed sensor removal (rear diff)
Old 01-21-2009, 12:08 PM
ahickman's Avatar
Trying to remove the speed sensor from the rear differential on a 94 3.0 4Runner. I can twist it side to side, but can not lift it out. Tried to gently pry it up using flathead, but no luck. FSM does not indicate anything special about removal. Am I missing something?
Old 01-21-2009, 12:18 PM
slosurfer's Avatar
First off, that is your ABS sensor, not your speed sensor on the rear diff.
Second, I assume you removed the one bolt that holds it on. It should pop right out after that.
Old 01-21-2009, 12:27 PM
Staff
DeathCougar's Avatar
Put the bolt back in, and step away from the rear diff!!!
Your speed sensor is located in the back of the transfer case. 3 wire plug going to it.
Old 01-21-2009, 12:35 PM
mt_goat's Avatar
If you still want to remove it...its probably just hung up on the rubber o-ring. Might try a little squirt wd-40 to wet the o-ring a little.
Here's a pic of what it looks like out:
Old 01-21-2009, 12:42 PM
ahickman's Avatar
Dale, thanks. Exactly what I was hoping for.
Old 01-23-2009, 06:17 AM
ZUK
ZUK's Avatar
I feel your pain try 2 screwdrivers and pry at opposite ends....work it up evenly.
Old 01-23-2009, 09:53 AM
ahickman's Avatar
Zuk, do you know if the ECU looks to this sensor for cruise control operation? My cruise control throws a normal code and I have checked just about every other sensor. Also have a problem with ABS and thought both CC and ABS might look at this sensor.
Old 01-23-2009, 09:58 AM
mt_goat's Avatar
My cruise control works fine without that ABS sensor.
Old 01-23-2009, 10:03 AM
ahickman's Avatar
Do you know if this is a hall effect sensor?
Old 01-23-2009, 10:34 AM
mt_goat's Avatar
I don't know, kind of looks like some kind of magnetic sensor doesn't it. What are you doing?
Old 01-23-2009, 11:40 AM
slosurfer's Avatar
My cruise control works fine with that sensor ziptied up by the gastank. So, like mt. goat said, I don't think the ecu reads that for cruise control.
Old 01-23-2009, 11:42 AM
Jay351's Avatar
good luck. those things break most of the time..
Old 01-23-2009, 02:32 PM
ahickman's Avatar
What effect on the ABS system does this speed sensor have if it is faulty? May be a stupid question, but from what it sounds like you could disconnect it without loss of ABS.
Old 01-23-2009, 02:49 PM
mt_goat's Avatar
... from what it sounds like you could disconnect it without loss of ABS.
I doubt it.
Old 01-23-2009, 03:57 PM
Jay351's Avatar
Originally Posted by mt_goat
I doubt it.
x2, doesnt that sensor detect the movement of the ring gear?
Old 01-24-2009, 07:20 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The speed sensor for the CC is on the back of the transfer case. Where DC pointed out. It also controls the speedo, odo, and tripmeter. Just an FYI......
Old 01-24-2009, 08:10 AM
slosurfer's Avatar
I doubt it.
x's 3, that is the only abs sensor on the rear axle, so I doubt the abs will work at all with it pulled. I can't say for certain as I haven't done any high speed stomp on the brake, stops since pulling mine. I'm just glad I was able to pull it and not have the abs light on all the time.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
ItsJustD
07-07-2015 07:49 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: speed sensor removal (rear diff)
