Spark Plug wires
Old Jan 21, 2007 | 05:21 PM
AUYota's Avatar
Spark Plug wires
I just had a few issues with spark plug wires. First time one wire melted on the EGR pipe but I didn't really notice it until it got real bad and the engine was working with it missing for a few weeks. It happened again, this time, a wire came loose from the dist cap. The wire was only barely loose for a long time as I notice it running a little rough but couldn't determine why. Eventually it came totally loose and I noticed it then. The end of that wire that plugs up to the dist cap had bad corrosion so I replaced the wires (again.) Question is, should I do anything else, or take any other actions such as replacing plugs (only 25k on em), since two cylinders were running without any juice for a few weeks or so?
Old Jan 21, 2007 | 06:20 PM
MudHippy's Avatar
Pull'em and take a look. Probably only slightly dirty, If that. Check the gap while at it, file electrode flat if needed. Course, plugs are cheap. But so am I.
Old Jan 21, 2007 | 06:35 PM
spudrunner's Avatar
What wires are you using OEM?
Old Jan 21, 2007 | 06:45 PM
95ToyotaPU007's Avatar
There should be sparkplug wire 'fingers' that keep the wires off the EGR pipe and exhaust manifold. If yours are missing I'd find some replacements. About the plugs, 25kmiles is just about time to replace them so I'd get a new set.
Old Jan 22, 2007 | 04:32 PM
AUYota's Avatar
I got some more expensive and nice wires at Pep Boys... Werner and something? I forgot. Are spark plug replacable without measuring stop gaps and such?
Old Jan 22, 2007 | 04:42 PM
slosurfer's Avatar
If you buy your plugs from the dealer, they should be pre-gapped. I would still check them though. A gapping tool doesn't cost very much.
Old Jan 22, 2007 | 05:04 PM
AUYota's Avatar
When at the Pep Boys he had pre gaped plugs and non gaped plugs... Anyone recomend a brand? NGK makes the OEM plugs I think. They help with gas milage right?
Old Jan 22, 2007 | 05:21 PM
spudrunner's Avatar
NGK plugs are best IMO. Borg Warner wires?
sandyota
Feb 4, 2021 11:16 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
