So my engine ate a washer....
Well here's the deal, I pulled my passenger side head of my 3.0 today. I was removing the head bolt closest to the firewall and the stepstool i was standing on slipped. Well you know that washer? Yeah it slipped off the bolt and fell right down the hole that returns oil back to the case. Any ideas or wisdom guys?
If you can't get it out you should pull the pan.
A tech at the dealership I used to work at droped a nut in the crankcase and when he started the engine the crank shoved it through the main bearing girdle and tore the bottom end up.
Depending on where it lands it may or may not cause big problems.
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
