So I Bought an '86 for $1000...
Old 05-25-2012, 08:17 PM
  #41
David Walker's Avatar
Originally Posted by matstaley
Google toyota groan stoppers. Someone makes them out of polyurethane or some such thing. Or just grease em and see if the sound goes away. I just put some real thick grease on mine every time I do an oil change. Never makes a sound.
GREAT! I found some:
http://www.drivewire.com/make/cat/gr...-cover/toyota/
Ranging from 1.39-18.60
I'll try the grease first though see how that goes. You think any kind of grease would do? If you don't mind will you let me know the specifics for the kind you have been using successfully?
Thanks again, super helpful.
Old 05-25-2012, 08:19 PM
  #42
Originally Posted by B-yodaful
If you want a good ride still and capability you should look into the blazeland Kit. and you wont have to spend $5000 to build what you want. http://www.blazeland.us/
These look promising. Anyone have any experience with these, and how they hold up over time?
Thanks. Great info.
Old 05-26-2012, 07:44 PM
  #43
Originally Posted by Luvmeye22re
Check this thread out. https://www.yotatech.com/forums/f116...inding-238600/
If you look under there I bet this is what you'll see or maybe even worse. This is likely the cause of that noise. It does sound terrible but it's normal.
Yep mine is worse. Not too much worse though. I am glad to fix it now, before I end up with a hole in that "rub plate". I cleaned some of the rust off with a wire brush, and added some brake grease I had laying around. It seemed to fix the problem for now. Thanks for all the help.
montanatruck
02-26-2017 07:07 AM
WellsR
12
07-31-2015 03:27 PM
karbin
07-05-2015 11:37 PM
Quick Reply: So I Bought an '86 for $1000...
