Smoke from dash, No power windows
Old 10-15-2010, 10:02 PM
icebear's Avatar
Had a small electrical fire behind the gauges. Not the flame kind, just the smoldering type. Gauges went crazy, but still work on and off. The power windows is another thing, they stopped working completely.
Question...Has anybody else had this happen to them, or hear if it happening to a friend, and what was it that caused it? or where to start tracking down the cause?
I know it a shot in the dark, but not good with the electrical stuff. Have to admit it scares the hell out of me to have to do anything but splice a wire.
Old 10-15-2010, 10:08 PM
myyota's Avatar
Its not a common thing that happens, but it does happen from time to time. You will need to take the dash a part to see what happened and repair or replace the burned wires and fuses.
Old 10-15-2010, 10:20 PM
icebear's Avatar
do you know what may have caused it? I dont want to replace and fix wires to have it happen again. Am I safe to guess it's something that doesnt have a fuse protecting it?
Old 10-15-2010, 10:27 PM
myyota's Avatar
There is no way i can tell you what caused it, it could be something as simple as a wire that rubbed through on a piece of metal and shorted out. The only way to know is to pull the dash a part and fix or replace what ever shorted out. There is no other way to fix the problem. If you don`t like working with electrical then you will need to take it to a shop and have them find and fix the problem.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Smoke from dash, No power windows
