Smelling fuel inside truck? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-19-2007, 03:40 AM   #1 (permalink)
I have a 95 4Runner with a 3.0 and I just started smelling fuel inside my truck yesterday and haven't had a chance to look at it. I was going to put it in my garage tomorrow and check my fuel lines, intake, exhaust, and fuel injectors. I haven't noticed a big drop in gas milage though I've only gone about 30 miles since the first sign of the problem. Has anyone else had this problem? Anyone have any other ideas where to check?
RabbitX77 is offline
Old 02-19-2007, 07:31 AM   #2 (permalink)
I had a fuel smell inside my truck that was strong when the heater was pulling outside air... and especially strong with the hood popped (coming from under the plenum).
I recently have put new HG on it, so I figured I didnt seat one of the injectors correctly or I forgot to tighten a bolt. It turns out that one of my injectors' O-rings had the smallest nick in it...we're talking tiny, but that was where the fuel was leaking from.
I would say let your truck run till you can smell the fuel, then shut it off and listen to hear if you can hear the fuel system leaking from any part of the fuel rail or injectors. I had to pull the plenum on mine... I hope you have better luck and dont have to. What a pain.
__________________
1991 4runner SR5 3.0, 5.71's, 33x10.50" BFG M/T, Lc Springs, Safari Snorkel, 199k miles, no swaybars.
1998 4runner SR5 3.4, 31X10.50" A/T, DD, K&N Fipk2, lifted 2", Bilstien HD's
Quote:
Originally Posted by DeathCougar View Post
what the hell fun is self control? Puke and Rally i say.
AuburnRunner is offline
Old 02-19-2007, 08:05 AM   #3 (permalink)
doc76239's Avatar
Send a message via AIM to doc76239 Send a message via Yahoo to doc76239
If you smell fuel, I would try to fix it out side if you can. Fuel vapor is realy explosive in a confined area such as your garage, not to mention if your vehicle caught on fire in your garage. Hope you find the leak soon.
__________________
Only in a YOTA, cause the force is with you.
92 4runner, 3.0, 5sp
K&N FIPK
doc76239 is offline
Old 02-19-2007, 08:26 AM   #4 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
I had a problem last summer with my gas tank. I could smell gas bad while I was driving. Turns out the metal line coming from the top of the tank had rusted through and was spraying gas. I replaced that line with a rubber fuel line hose and seems to have fixed it.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
rdlsz24 is offline
Old 02-19-2007, 02:16 PM   #5 (permalink)
I had this problem in my old yota and it turned out to be the fuel pulsation dampener. It's a pretty easy fix, you take off the plenum and it's under there. Maybe a 2-3 hour fix for a novice mechanic like myself. The part cost me $200 from the dealer though... ouch. If I remember correctly, after the truck has been driven, go under the hood and listen for a dripping sound coming from the driver side behind the air-intake manifold, if you hear dripping, it might be the fuel pulsation dampener, the dripping is the fuel.
Search for "fuel pulsation dampener" for more info.
BTW: I would be willing the pull the one out of my old truck and sell it to you, it's essentially brand new. My old truck is rotting away in my backyard.
Trinok is offline
Old 02-19-2007, 02:35 PM   #6 (permalink)
Crux's Avatar
Last summer I had fuel ordors coming from the engine as well.
Turned out to be a corroded/rotten fuel return line. Easy to replace.
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB
04 Land Cruiser Grey - 90k miles, OME Lift, Slee Sliders, 35" Toyo Muds
Crux is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
HOT after long trip inside truck!? Yota Beave 86-95 Trucks & 4Runners 7 07-09-2007 09:22 AM
What is Burnt smelling Trans fluid? cancow 95.5-2004 Tacomas & 96-2002 4Runners 3 02-22-2006 05:46 AM
HELP! Truck wet inside after rain. cstary 95.5-2004 Tacomas & 96-2002 4Runners 18 05-03-2005 02:13 AM
Tag sugestion for my truck..pic inside Kerr Off Topic Talk 17 07-18-2003 01:09 PM
Smelling gas..... RgrChu 95.5-2004 Tacomas & 96-2002 4Runners 6 02-09-2003 06:19 AM
2009 InternetBrands, Inc.
