Which shackles should i get? 93 4x4 P/U
Old Jun 27, 2008 | 09:55 AM
Dasuprawolf's Avatar
Well i got my Downey springs yesterday and was going to install them last night at work. I got all new hardware and shocks but the only thing i didn't get was shackles. I was planning on just sliding the spring off the OE shackles (yea right) the inner metal bushing is corroded to the shackle bolt, but after 312K miles in Michigan thats expected. So now im going to get new shackles so i can just cut it all off.
I've been searching here for which ones to get, I'm looking at the WabFab because there greaseable, or Marlin. What i noticed with both is that the sides of the shackle are straight but the OE ones have that offset in them. at the frame there wider than at the spring, and ive read that a lot of people have trouble getting the wrong bushings too?
What ones did you get? get everything you needed? What ones should i get?
Thanks.
Old Jun 27, 2008 | 04:16 PM
bump. please i need to order.
Old Jun 27, 2008 | 06:21 PM
nmtoy's Avatar
I have these on my 90 extracab and like them.
http://www.marlincrawler.com/htm/sus...n/shackles.htm
Robb
Old Jun 27, 2008 | 07:10 PM
Robb
and everything fit fine? The bushings were right? what about the difference in the width at the frame and spring?
Sorry for all the questions....
Thanks, Brian.
Old Jun 28, 2008 | 04:18 AM
nmtoy's Avatar
Bushings fit fine, the shackles have a spacer on each side of the spring to compensate for the difference in width.
This is the best pic I have right now
Robb
Old Jun 28, 2008 | 04:20 AM
sweet, thank you
Old Jun 28, 2008 | 05:03 AM
waskillywabbit's Avatar
Talking
Thanks.
With dozens or more spring combinations and variables, not all bushings are going to fit all springs...just like all tires don't fit the same car...different sizes. The shackles on most of the off-road websites are for off-road applications with the springs they use, not another companies, yet there is some commonality in the setups.
That being said, no pair of shackles (with bolts/bushings) is going to fit every application and you shouldn't expect it to.
Shackles:
http://www.wabfab.org/products/suspension/shackles.htm
Narrow rear shackles fit 79-88 Pickups and 84-89 4Runners. Wide rear shackles fit 89-95 Pickups.
Stock height is 3.5" so anything over that divide by two and that is typically the amount of lift they provide.
Old Jun 28, 2008 | 05:33 AM
mt_goat's Avatar
I love my 4Crawler shackles, read up:
http://www.4crawler.com/4x4/ForSale/Shackles.shtml
Old Jun 28, 2008 | 05:07 PM
nmtoy's Avatar
I have a set on my 4runner, I like them as well.
Robb
Old Jun 28, 2008 | 07:06 PM
Shackles:
The bushings im concerned about are the ones for the frame hanger, I have bushings for the spring end.
Old Jun 29, 2008 | 04:34 AM
dirtoyboy's Avatar
I like AORs shackles...unfortunately they are out of business now!
Flying91
45
Apr 11, 2024 04:39 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
mussy01
Dec 13, 2016 08:20 PM
defrag4
Jul 31, 2015 10:50 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
