Shackles installed!!!!
Old 02-15-2010, 02:53 PM
DethYota's Avatar
I like the idea of lifting your vehicle only as much as needed. It seems like those are some nice size tires already. I would of put those shackles on the first or second hole just to get the exhaust out of your springs. Putting on bigger tires means you are gonna do some more hardcore off roading. Be careful! We don't wish harm on anyone whether it be on the board or in Life.
Old 02-15-2010, 03:05 PM
blueyota38's Avatar
So that means the shackles buckell strength is more than 9000lbs so i believe they will be fine. And i dont do to hardcore stuff but like the look of bigger tires and the offroad traction provided from them being bigger!!! Thanks for that buckel info to!!!
Old 02-15-2010, 03:29 PM
myyota85's Avatar
Well i ran mine on the second hole 4 about 2 years and all they did was warp the springs down. Dont really think u can break them. Just my 2 cents.
Old 02-15-2010, 03:33 PM
blueyota38's Avatar
Thanks man. did the rig you had them on have an ad a leaf on the spring as well?
Old 02-15-2010, 03:44 PM
  #25
myyota85's Avatar
Talking
No they were 4 inch lift springs. If i were u i would wheel the hell out of it. If they start to sag then save up for springs.
Old 02-15-2010, 04:12 PM
  #26
iamsuperbleeder's Avatar
Originally Posted by blueyota38
And i dont know what your talkin bout, my pinion pointin at my transfer case?
longer shackles only move the rear mount of the spring away from the frame, thus causing the axle to pivot and make the pinion point upwards, or point "towards your transfer case"
actually, that change things for the rear u-joint so much, but the u-joint at the transfer case is going to wear quicker, becuase it's at a steeper angle now. Not much steeper, but enough to make a difference in the wear interval, and in some cases cause drive-line vibration
idealy, you want the drive-line to be as straight as possible. Obvisouly the drive-line is never completely straight, hince the need for u-joints but the straighter the better, and the longer the u-joints will last. this is of caurse pertaining to daily drivers... trail-rigs and offer-road vehicles in general, you can pretty much expect to replace u-joints regularly, lol
Old 02-15-2010, 04:31 PM
  #27
Fink's Avatar
I've got a pretty vicious driveline vibration in my '85 from the lift.
Fink
Old 02-15-2010, 04:32 PM
  #28
blueyota38's Avatar
Well i no what your talkin bout but it didnt make that big of a difference to were i would be worring about that. only raised the truck about 1.5in! no big deal.
Old 02-15-2010, 04:48 PM
  #29
RustBucket's Avatar
Superbleeder, from what I have read driveline vibration occurs more when you have u-joints at unlike angles. Basically, you want the diff pinion and tcase shaft to be parallel so the u-join links them through a vertical distance.
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old 02-15-2010, 05:02 PM
  #30
that's precicely the situation a shackle lift brings up, I just didn't go into depth about why exactly the drive-line vibrations accur
mine's got an ever-so-slight, but noticable vibration too, because of the longer shackles from WabFab, and so far I've only have to replace my u-joints once with the shackles... but I've only been running the shackles about a year, so we'll see
Old 02-16-2010, 03:45 AM
  #31
blueyota38's Avatar
Well my angles were worse without the shackles? haha so i guess i just solved a problem!!! My drivshaft is straighter now.
Flying91
45
04-11-2024 04:39 PM
nvdesertrunner
05-11-2020 08:18 PM
Jcrawl94
10
10-24-2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
Shagool22
08-14-2015 12:24 AM
Quick Reply: Shackles installed!!!!
