seats
seats
So my dads friend is looking to replace the 60/40 seats in his T100 with some bucket seats. so my question is what bucket seats do u guys think are the most comfortable and will replace the stock seats with the least amount of modification. thanks for any advice given i appreciate the help.......
Im not sure about being easy to install, but i know that buckets are the most comfortable to me
but, make sure to get nice buckets that have lots of adjustment stuff
I replaced my 60/40 with buckets also. They came out of a runner. Three of the four bolts lined rt up. It was the front inside bolt. Just had to drill a new hole and boo-bam it worked great. Hope this helps
Laterz
Laterz
personally i like the bench seats...the girls like them too...just remember guys...you cant lay across 2 bucket seats...but you can lay across a bench seat...and the girls would rather have the bench too...for...certain reasons...lol
I dont know if 4runner seats will bolt to the T100 but by the sound of it so far its seems they might. T100's with buckets should bolt right into you truck im sure of that!
Search some more I bet this info is out there!
Good luck
Good luck
Go with the buckets. If needs be, that's why god invented the rollbar. Just roll'er over that bar there and proceed to giving your truck's shocks a workout.
thats what the beds for...they call it a bed for a reason
A ton of seat install info. Also do a search as there is a ton of good advice in other threads on here
Forget about it if you drive a standard. Best to park the beast to play with the beauty. Learned that lesson the hard way my friends.
awwe maan... i need a life...
MKII Supra bucket seats are actually very comfortable. They have an inflatable air bladder with 3 separate pockets you can adjust for lumbar support.
Not sure if they're a direct bolt in, but you could fab up a mount pretty easily.
kawazx636
10-06-2021 03:03 PM
punks_is_4x4
02-26-2016 04:29 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
