Seafoam>Where and how to add to our trucks
Old 07-26-2008, 12:41 PM
Myron's Avatar
I did a few searches and could not find what im looking for...
Basically i want to run seafoam through my system.
I heard about different places you can put it through.
What is the best place to have it put in from and how much do i use.
thanks
Old 07-26-2008, 12:51 PM
Fink's Avatar
It doesn't matter what engine you have, you can pretty much put it in the same places.
This is really the only thread you'll need.
Fink
Old 07-26-2008, 12:52 PM
Staff
DeathCougar's Avatar
Right into the vacuum line for the intake. Then put some in your gas tank, and some in the crankcase. Helps clean it all.
But just follow the directions on the can, and you will be fine.
Old 07-26-2008, 12:57 PM
4Crawler's Avatar
I pulled the purge hose off the charcoal cannister on my '85 and used that to suck Seafoam into the intake. Worked well since the small diameter made it easier to control the amount sucked in and also it is a long hose, so easy to reach the can.
Old 07-26-2008, 02:51 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
There is also some youtube video's with people doing the seafoam treatment on our trucks. And you can buy it anywhere....autozone.....advanced autoparts...
Old 07-26-2008, 04:05 PM
854x4's Avatar
Heres a writeup I did awhile back should help.
http://board.marlincrawler.com/index...hlight=seafoam
Old 07-27-2008, 01:39 AM
Myron's Avatar
thanks for the info..I give it a shot and let you guys know
Old 07-27-2008, 05:30 AM
bigt's Avatar
your neibours ready for a smoke out?
Old 07-27-2008, 09:41 AM
Myron's Avatar
Cant wait to see who comes outside. LOL
Old 07-27-2008, 09:47 AM
abecedarian's Avatar
...or how long it takes the fire department to show.
anyhow, I did seafoam on my 91 through one of the vacuum lines on the throttle body and it smoked bad.
then I did my 88 with spray MAF cleaner- took the duct of the throttle and sprayed about 1/4 of the can up through the throttle, let it set about 10 minutes, sprayed another 1/4 can up and buttoned it up and started it. smoke is an understatement. looked more like a WWII smoke screen being layed out. then I did it again and not so much smoke. and the truck has quite a bit more torque now than before, not as much downshifting.
so either way, you should see a benefit.
Old 07-28-2008, 03:55 PM
Myron's Avatar
Didnt see too much smoke like i think i should of.
Im going to try it again and put a little more through the break booster again..or should i try a different hose
Old 07-28-2008, 04:15 PM
basically, you run it in until the engine dies. then wait a few minutes. then start the engine.
Old 07-28-2008, 09:48 PM
Myron's Avatar
I ran it but the engine did not stall..i ran exactly 1/3 of the bottle.
Should i let it stall out? if so...im sure i will be using more than 1.3 of the pint
also could i run half the bottle in the crank.. another pint in the gas tank and do half through the brake booster?..is that too much seafoam?
Old 07-29-2008, 12:09 AM
toyotatom93's Avatar
Some people have reported hydrolocking the motor from pouring in too much. I reccomend using more than a third of a can, and doing multiple treatments.
I also find my truck smokes more as I am pouring it in the brake booster line then after I let it sit for a while.
Old 07-29-2008, 05:51 AM
Crawdad's Avatar
Where did you hear of someone hydrolocking?
Old 07-29-2008, 05:52 AM
1987tanyota's Avatar
go to 4x4fink's link up at the top theres the stroy there
Old 07-29-2008, 06:12 AM
algranger's Avatar
i just pour it down my pcv hose and put it back on and fire it up ive done it on 3 trucks and a rider lawnmower (haha that was fun) and ive found the more gunged up the engine is the more it will smoke
edit: i pour it down the throat of the carb too
Old 07-29-2008, 06:14 AM
really the carb throat? thats interesting.... didn't know that would work... one guy here at work said he did that and it was fine another said NO WAY
Old 07-29-2008, 09:07 AM
It was here, dont remember when or who but I definetly remember it. The guy stuck the hose right in the bottle I believe. And people mention not to pour too fast into the booster hose for the same reason.
Old 07-29-2008, 09:43 AM
rusche's Avatar
I did mine in the PCV hose, twice. Half a can, stalled it. Waited 15, started her up, smoked like nuts. When she was done smoking I did it again, the other half can. This time I dumped alot in when I stalled it, and let it sit for atleast 20 minutes. Smoke was an understatement. Took me like 10 cranks to start her but by the time I did I couldnt see where I was driving, it was rediculous. Worked like a charm though.
Quick Reply: Seafoam>Where and how to add to our trucks
