Rotor removal
Old 07-06-2011, 06:16 PM
96vettelt4's Avatar
Rotor removal
95 yota pickup 4x4 22re..man. hubs..when taking the rotor/hub unit off does the man. lockout with the 6 bolts need to be removed before the rotor /hub unit will come off?...thanx....G
Old 07-06-2011, 06:32 PM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old 07-06-2011, 07:11 PM
96vettelt4's Avatar
I have and looked at the FSM but it says to remove the hub and rotor as a unit ..not if it clears without removing the part I was asking about.. ..thats why it was a question..i did a search and looked at the FSM many times but it doesnt answer my question...thanx...
Old 07-06-2011, 07:15 PM
You are going to have to pull off the wheel hub as the rotor is on the back of it.
Manual hub dial bolts.
Axle clip/bolt
54mm nut, star, nut, washer
Nuts, cone washers, flat washers.
Then the wheel hub will come off.
:wabbit2:
Old 07-07-2011, 05:10 AM
TNRabbit's Avatar
You'll also want an impact wrench to get the bolts loose & an impact hammer to chisel the rotor off the hub. Not required, but it will make your life TONS easier~
Leviticus6432
11-20-2015 05:06 PM
Jcrawl94
10
10-24-2015 04:34 PM
romex1
08-10-2015 06:21 PM
ahriman
08-01-2015 10:38 AM
msane99
07-11-2015 08:08 PM
Quick Reply: Rotor removal
