Old 03-30-2016, 11:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Electrical Guides
Print Wikipost
replacing battery cables
Old 02-14-2006, 03:20 PM
Kyle95sr5's Avatar
I have searched but haven't found out any how-tos. I noticed my battery terminals and cables are basically shot. sometimes my 4runner won't start up so i have to pop the hood and wiggle around the terminals to get it to start. I want to replace both of the cables and terminals. How do you replace the batter cables (both postivie and negative). im such a noob so i thought it couldn't hurt to ask. anyone have directions or a write-up or anything. Thanks.
-Kyle
The following users liked this post:
Kristy Cogswell (03-24-2021)
Old 02-14-2006, 09:01 PM
Morphine's Avatar
I am not a mechanic so truct me when i say that this is not that difficult to do yourself. You'll basically disconnect the cables from the battery, follow the cables down (in mine they were housed in a loom and had a connected plastic housing that attached to the frame below the power steering pump). You'll unhook this plastic housing, removing the positve cable from the starter, mostlikely you'll be able to unattaached it from the passanger side wheel well or from under the vehicle. Then you'll remove the ground (from the block - REMEMBER where this was connected --mine had many options to choose from it seemed when I reconnected mine).
Head down to the auto parts store and match up the length and then begin the installation process. I would advise to start up top, lower the cables down, connecting them to the block and the starter then re-work the plastic housing and loom. From here on out you should be good.
Hope this helps and good luck.
-=Morphine=-
Old 02-14-2006, 10:49 PM
Flamedx4's Avatar
Yep, couldn't be simpler. get some masking tape and label everything, then there is not chance of an error.
Old 02-14-2006, 11:02 PM
Jeffires's Avatar
Are you sure the cables are bad and it's not just the terminals? Either way, I'd put some heavy duty terminals on. I put brass marine terminals on mine, and it worked out good for connecting accessories.
Old 02-15-2006, 06:00 AM
midiwall's Avatar
Searching on "battery cables" gives:Then, one of those would lead you to "big 3":There are more...
Old 02-15-2006, 12:01 PM
surf4runner's Avatar
since he probably wont read them...
disconnect the NEG terminal/cable FIRST!
Old 02-15-2006, 05:07 PM
Kyle95sr5's Avatar
thanks guys for all the help..ill definetly be doin this soon very soon. Midiwall..thanks for not verbally thrashin me but i read all of those threads posted before i posted my own thread. I believe that only the last one in the "battery cable" section actually provided instructions and that was only for the negative cable..i did search for both of them first and couldnt find anythinig for both..but thanks anyway. will 4 guage wire work just fine guys??
-Kyle
kazuya2416
04-05-2024 02:17 AM
shar
07-09-2015 12:38 PM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: replacing battery cables
