| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Removing headlamps
__________________
99 4Runner 97 4Runner 4wd 93 Supra 90 LS400 86 Pickup 4x4 |
#2 (permalink) |
You can unscrew the two adjuster screws all the way and release the springs and pull the lamp out that way. You will need to align the headlights afterwards. Might try marking where the beams fall on a garage door or wall before and that way to can reset them close afterwards. Put in a set of H4 lamps and in the future you only need to swap out the bulbs in back of the lamp instead of replacing the whole assembly:
- http://www.4crawler.com/4x4/CheapTri...#BrighterBulbs
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
what i did when i put my new front end on was i took a disk sander to the head of the screws holding the headlights in and grinded them down, try sanding on a low speed. then drill through the rest of the existing screw holding it in and put some larger diameter stainless sheet metal screws....do this only of course if soaking the screws in wd-40 or something like that doesn't work first.
ps. you need to take off the grill to do this. Last edited by 89red4x4yota; 12-23-2006 at 12:59 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 96-98 4runner headlamps | Localmotion | The Classifieds GraveYard | 5 | 02-19-2006 09:37 PM |
| Strange Wiring Problem with headlamps | mjwalfredo | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 12-04-2005 11:46 AM |
| projector headlamps | MotaPsycho | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 07-17-2005 05:55 PM |
| Upgraded Headlamps from Burtman Industries | Sherpa | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-02-2005 07:55 PM |
| Good prices on new '99+ headlamps | X-AWDriver | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 07-12-2004 04:55 PM |
