Rebuild update
Old 10-16-2008, 04:29 PM
Blackjet's Avatar
Rebuild update
Well after getting another head to replace the cracked one i thought i was on my way to getting everything machined. Wrong! Now they tell me the block is cracked. So i'll start looking for a replacement. Does anyone know the years that are the same as a 1990 3.0 v-6? Also anyone have a block for sale in arizona i,m looking.
Old 10-16-2008, 04:30 PM
AZ89LONGBED's Avatar
dude, 3.4 swap...
Old 10-16-2008, 04:35 PM
abecedarian's Avatar
89-95 blocks should be fine for you. I've heard rumours the 88 v6 block doesn't have the same engine mounts.
considering things though, az89 may be correct in suggesting a 3.4 swap- the cost of a 3.0 block and work may be nearly equal, or not cost-effective in the long run, to swapping to the 3.4
but I wouldn't know that off hand as I'm a 22re man.
Old 10-16-2008, 04:42 PM
Blackjet's Avatar
Many times now i wished i was a 22r man.
Old 10-16-2008, 04:46 PM
87TurboYota's Avatar
Am I the only one that drives down the road looking really hard at the bottom driverside corner of the grill of other trucks and 4runners of our generation for the V6? When I see it I'm like that sucks it could of been something good.
Old 10-16-2008, 04:57 PM
Blackjet's Avatar
Smallblock with a blower would really look cool
Old 10-16-2008, 05:19 PM
KevinInSac's Avatar
I believe there was a change in engines after 92. I don't know the exact details, but some things were switched around.
Old 10-17-2008, 03:52 AM
Cyberman's Avatar
The timing belt tensioner changed after 92.
Old 10-17-2008, 06:07 AM
1styota4X4's Avatar
i will have the motor out of my 95 pulled here shortly...it has a weird tick cant figure out what it is...it's the #2 cylinder...Let me know if interested. I found a local truck with 35k on the odo. I picked it up for 1000 so i am puting that motor in my truck
Old 10-17-2008, 06:37 AM
YoterUp's Avatar
i just swapped a 93 to a 90 with no problem but a cracked block to i have a whole build up on here of it with the motor rebuild and all.. if the cracks not to bad you can have it sleeved at any machine shop mines there getting it done right now i should have it back by monday or tuesday ill post pics of it. i think hes only charging me like $125. might be easier then finding a whole new block. and from what everyone has told me its just as good.
Old 10-17-2008, 06:40 AM
874runnersr5's Avatar
hahahaha
Old 10-17-2008, 10:12 AM
space-junk's Avatar
that kinda hurts my feelings...
anyways, yea, the tensioner did change as well as a couple other things... toyota decided to make some stuff more beefy on them... like accessory drive supports, and tensioners...
Old 10-17-2008, 10:19 AM
toyospearo's Avatar
ahhahahhaha, me too!
After working on a few of them I Immediately loose interest when I see the little V6.
Old 10-18-2008, 04:10 PM
Blackjet's Avatar
After two weeks of cracked parts-the update is i'm drinkin beer and listenin to rock!
Obmi
11-24-2015 11:37 AM
viesail
09-21-2015 06:00 AM
sonorn67
09-19-2015 05:39 PM
Kylenicoll33
09-17-2015 08:40 AM
--Oz--
09-06-2015 01:06 AM
Quick Reply: Rebuild update
