Rear spewing from the breather hole
Old 05-22-2014, 07:50 AM
BaldEagle65's Avatar
My '88 pick up is for some reason blowing the rear-dope out the top of the chunck (breather hole is what I'm calling it) . anyone able to tell me why this is happening?
Old 05-22-2014, 07:58 AM
AdmiralYoda's Avatar
Rear brakes, rear end, rear main seal, rear transmission seal, rear transfer case seal, rear of the engine? Could you be a bit more descriptive of the problem and where it is?
Old 05-22-2014, 08:08 AM
The rear end...from the drive shaft side of the chunk, top right.
Old 05-22-2014, 08:23 AM
millball's Avatar
Did you get any water in it.
I've seen 'em blow pretty good when they try to cook the water out.
Old 05-22-2014, 08:42 AM
Crack the fill plug and look inside. If it looks like a milk shake you have water in there. The gears turn the oil/water into foam. As the air bubbles build up and the foam expands it has nowhere to go but out the breather.
Go in any deep water lately?
Old 05-22-2014, 08:47 AM
Can't say that I have been in any deep water in the last year. I drive this truck daily. Has 385,000 on the meter. I noticed the smell of gear oil about a month ago. Took a look to see where it was coming from and noticed it dripping from the under side of the bed. Guess I'm just dumb struck as to why it would be blowing the oil out. I'll take a deeper look into it in a bit and post my findings. Thanks guys
Old 05-22-2014, 12:08 PM
osv
osv's Avatar
did the little cap come off of the breather?
or maybe the breather got plugged, so that the rear end would build up pressure when hot, then spew out.
Old 05-22-2014, 01:01 PM
must have, for I don't recall seeing a cap of any sort.
Old 05-22-2014, 01:24 PM
osv
osv's Avatar
here are several pics of what it should look like
https://www.google.com/search?newwin....0._sAmsuhowXg
Old 05-22-2014, 05:32 PM
Teuf's Avatar
Huh, I just Unplugged mine yesterday. I got my truck oct, 87. I don't think I ever have looked at it until yesterday.
Old 05-22-2014, 05:50 PM
it doesn't have cap or a hose connected to it. Should it have the hose ?
Old 05-22-2014, 06:20 PM
nv4runner's Avatar
I installed a hose on my front and rear diff, but if you never get into deep water it should be fine without it. They do tend to clog up though.
scottyg486
07-19-2015 05:34 PM
Iceman4193
07-15-2015 04:48 PM
voiddweller
07-15-2015 03:56 PM
icentropy
07-14-2015 10:23 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Rear spewing from the breather hole
