rear heater...removal or replacement?
Old 12-16-2007, 12:12 PM
Belize Off Road Team's Avatar
well since i now live in Belize, i have been thinking it would be nice to have either more storage or a cooling fan rather than a heater. so is there anyone out there that has done this? cause it might be the place for my on board air compressor for the ARB lockers or what ever is needed i guess.
Old 12-16-2007, 12:16 PM
bigt's Avatar
last week my lines rusted out the rear heater... so i bypassed right in the engine bat by the firewall.. and im thining about choping up my console or taking it out too..
sorry im not more help
ill check back in later
Old 12-16-2007, 08:58 PM
InternetRoadkill's Avatar
I removed the lines to the rear heater on mine. You just need to block off the connections on the fire wall. After than it's a simple matter of removing the lines under the floor and the rear heater itself. You will need to block the hole in the floor where the water lines connected to the the heater core.
There is one problem: The center console bolts to the top of the heater. If you remove the heater, you'll need to fabricate a new mounting bracket for the console.
Old 12-26-2008, 02:37 PM
RoBatt's Avatar
i tried to remove my rear heater today and i unscrewed the 4 bolts around it but it wouldnt lift off... any help?
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: rear heater...removal or replacement?
