Radiator fan has stopped kicking in
Old Jun 30, 2008 | 08:28 PM
Kinked's Avatar
I have a 91 4runner, latley while i've been out wheeling its been over heating like a mother i looked at the fan and it isn't kicking in. it goes full force when i start the truck, but once that is done it doesn't kick in again.
just had the engine rebuilt about 9000km ago, i'm not blowing white smoke, it just runs hot when i'm wheeling. any ideas on what makes the fan actually kick in, or any ways to check whats wrong with it
cheers
Old Jun 30, 2008 | 08:45 PM
CC_yota's Avatar
I may be wrong, but if the fan isn't turning then you're clutch has probably seized up and is due for replacement.
Old Jun 30, 2008 | 08:50 PM
Kinked's Avatar
when the engine starts it turns just fine, after about 20 seconds or so... it just spins, but not with any force. almost like its just spinning because of the engine... if that makes any sense
Old Jun 30, 2008 | 08:59 PM
Matt16's Avatar
Fan clutch is fried.
Old Jun 30, 2008 | 09:07 PM
1990Runner's Avatar
x2 on clutch fried
Old Jun 30, 2008 | 11:43 PM
Matt16's Avatar
Just to clarify, we are not talking about the flywheel clutch that you disengage with your left foot, but the clutch that the fan bolts to.
Here's a picture.
Old Jun 30, 2008 | 11:46 PM
stormin94's Avatar
Definitely get that fixed ASAP, esp. if you have the 3.0 V6. You don't wanna get those baby's hot. Maybe time for electric fan mod?
Old Jul 1, 2008 | 09:52 AM
Kinked's Avatar
unfortunatly i'm in a place that doesn't really have much in the line of anything... i'm gunna try to get a fan clutch sent out.. but the electric idea... don't thinkn i could find one around here
thanks for your help
Old Jul 1, 2008 | 10:00 AM
bigt's Avatar
if theres a junkyard they will have a ford taur or lincoln with the electric fan you want!! i got a fan clutch on ebay with the fan blade for 5 bucks plus shipping..turns out it was just a loose belt in my case so now i have a trail spare
Old Jul 1, 2008 | 11:13 PM
stormin94's Avatar
Where is Coquitlam?
Old Jul 1, 2008 | 11:29 PM
Jay351's Avatar
In the lowermainland of British Columbia (Canada)
Old Jul 2, 2008 | 04:45 AM
Kinked's Avatar
i'm posted to wainwright alberta right now... not at home where this would be an easy fix unforunatly
Old Jul 2, 2008 | 10:29 AM
Jay351's Avatar
well thats lame!
Old Jul 2, 2008 | 10:44 AM
4Crawler's Avatar
Try pulling the fan and clutch out and have a look at the center of the bi-metal spring assembly. Sometimes the shaft that the spring turns gets stuck and that prevents the internal valving from changing to lock the clutch up. My '85 did that and I was able to free the shaft by gently turning it with a pair of pliers.
Old Jul 2, 2008 | 10:59 AM
t4r2wder's Avatar
I have the problem but in reverse. Fan runs all the time, cool wooshing noise on revs but robbing fuel and every little horsie power is needed. I like the electric idea. Anyone got a link to instructions/parts?
Old Jul 2, 2008 | 11:30 AM
Jay351's Avatar
Well, you might want to figure out why its staying on. Is the clutch done or are you having cooling problems?
Old Jul 3, 2008 | 05:36 AM
t4r2wder's Avatar
Temp guage is staying nice and low. I am able to manually move the fan after everything has cooled down, not freewheeling but it does move. Since the only harm now is a mile per gallon I'll wait and see what happens in the fall. This is the first summer with the truck and it is TEXAS.
Old Jul 3, 2008 | 05:39 AM
4Crawler's Avatar
You could try rebuilding the fan clutch or just get a new one. I replaced my original clutch with a new Aisin unit from Toyota about 6 years ago and saw nearly a 1 MPG mileage improvement. The old clutch was just getting too stiff and not releasing. I figured it would make a good trail spare.
Old Jul 4, 2008 | 08:35 AM
Kinked's Avatar
Just got the new clutch, i'm gunna try to put it on tonight when i'm off work, anything that i should know about (ie. weird things about the fan) before i begin
Old Jul 4, 2008 | 11:11 PM
Kinked's Avatar
new fan clutch is in, now all i have to do is test it, thanks for all your help, hopefully this fixes the problem
