questions about Chevy Springs
Old 09-19-2008, 09:00 AM
Countryhick's Avatar
I wanna put 63'' chevy springs on my yota. should i straight axle it first or save money keep it ifs.
i have a 5inch suspension lift already iwanted to add thechevy springs with that and get 35's. along with 4:88 Gears.
Anyone give me ideas on what to do and how to do it.?
Please anything will help. im a teenager with big dreams.
Old 09-19-2008, 09:10 AM
ryantowry_81's Avatar
I would say do the chevies now and save up for the SAS. the chevies shouldn't cost much and will still work with the IFS and flex mad!!
I dove into chevies rear and RUF on my 84 and i have been busting a$$ to get it done and i wish i could have done it in steps so i could tune the rear first then the front instead of going out with all new susp.!!
but you can do it i did my chevy rears in 18 hours, but i had to plate the frame majorly because i ripped the old spring hanger off!! and i fabbed every bracket from scratch so that added some design time.
Old 09-19-2008, 09:13 AM
Yeah i was going to switch out my springs now go find old chevy springs fit them all 4 around and have itjust for now. and SaS it and keep the springs for fun and flex mad. its just my wheeler nothing more so im making it into that.
Thanks alot for your help
Old 09-19-2008, 11:31 AM
trbizwiz's Avatar
Do the Chevy's first then you can reuse your existing rear springs on the front save $$$. Before you take anything apart, make sure to get the 9/16 bolts out of the Chevy springs first. That can take a while with penetrating lube and a BFH. After thats done plan on replacing the marshmellowed out factory 9/16's inch bolts with new grade 8 bolts. You might as well get energy suspension poly bushings for the Chevy's too, especially if you need to use heat to get them apart.
Good luck on the swap, it's an adventure.
Old 09-19-2008, 02:35 PM
tc
tc's Avatar
How are you planning on using the truck?
Can you weld well enough to bet your life on it?
MY recommendation would be to spend all this money burning a hole in your pocket on gas and girls.
Old 09-19-2008, 03:13 PM
jason191918's Avatar
What tranny do you have? You should get 5.29's for 35's (steeper yet if you have an auto)
Old 09-19-2008, 03:18 PM
who regears? i'm still running 4.10s with 40's!!!! hahaha
no you are right regear is definately worht the money if you can afford it, and personally i would go with 5.29's after you SAS no matter what tire you run
Old 09-20-2008, 12:10 PM
85toy's Avatar
whatever you do dont put any money into your ifs like a locker or gears. i vote for chevys now and sas later.
Old 09-20-2008, 01:40 PM
Mic09dcsm's Avatar
Just throw some 28's on there afterward, 4WD burnouts FTW! lol
Old 09-21-2008, 10:45 AM
Matt16's Avatar
Do frt/rr lockers and you'll be amazed. No flex needed (almost). I'm certain a truck with a lockers will out wheel a SAS truck no locker.
Old 09-21-2008, 08:10 PM
tc
tc's Avatar
GAR-ON-TEED
Old 09-21-2008, 10:43 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
x2
unless you go over big huge rocks, a SAS will probably not be near as beneficial to you as lockers/gears.
also, SAS should be one of the last things to consider. lockers and gears, armor, tires and lift, in that exact order, above all else, if you are really serious about wheeling. if you want to mall crawl (which is perfectly fine, 99% of my Jeep buddies are that way), do the lift and tires and forget the rest.
good luck!
Old 01-07-2009, 04:59 AM
looseballjoints's Avatar
When you did the rears up front, did you use the leaves as is, or did you add leaves to the pack? Did you use the stock hangers?
nvdesertrunner
05-11-2020 08:18 PM
priest16
15
08-06-2015 07:43 AM
defrag4
07-31-2015 10:50 AM
coffey50
07-28-2015 10:55 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: questions about Chevy Springs
