Pulling codes on a 92 V6 4x4
So my check engine came on today. I tried pulling codes and nothing on the dash is flashing. Isn't the check engine light suppose to flash a certain number of times? I have the service/diagnostic port jumped with a paper clip, and nothing is going on. Can anyone shed some light on this...
Sometimes the paper clip trick doesn't make good contact with the terminals so you may want to use a short piece of stranded wire or find crimp terminals, to put on the end of a piece of wire, that fit into the terminals... I believe it should be flat/blade type connector 0.125" wide.
Also, don't start the engine- just turn the key on. (Not saying you did this but....)
yeah i can't tell if it's making a good connection because of the electrical grease toyota uses. I'll give that a try. I was thinking about taping into the wires and adding a on/off switch.
some drunk guy
08-03-2021 06:09 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Armstrong486
09-19-2015 12:37 AM
