problems with body lift install
Old 09-26-2010, 10:43 PM
JoeC's Avatar
I got my truck lifted 3" on the cab so far, everything was going good until I got to the steering department.
I have a 3" performance accessories body lift; 5503M. this is on a 2wd p/u 1994 with no power steering.
Any ways.. it comes with a steering extension, nice solid aluminum piece that has been machined with male and female splines. After reading the instructions and the funky wording they use; aka.. steering coupler, steering joint, and not giving absolutely clear pictures showing where it installs; I assumed the extension went under the dash; and after a while we got it on there, but now the problem.. We cant get the other end onto the steering box. Not unless we dropped the steering column, but even then; how do I know it would even be able to get bolted back afterwords..
If I put the extension on the steering box; will I run into these fitment issues? Has anyone else installed a 3" performance accessories body lift on a 89-95 toyota pickup, 2wd or 4wd, its the same kit. maybe let me know what you did? Thanks!
Old 09-26-2010, 10:49 PM
gary96360's Avatar
extension goes where the shaft goes to steering box
Old 09-26-2010, 10:51 PM
gary96360's Avatar
loosen the bolt undernearth the dash where the mini u joint is. unbolt shaft fromsteering box. pull the steering shaft back
Old 09-26-2010, 11:17 PM
JoeC's Avatar
I'll give that a try tomorrow and see how it works out. You have any pictures of the extension on your box?
Old 09-27-2010, 11:46 PM
gary96360's Avatar
yeah ill take a pic tommorow
Old 09-27-2010, 11:51 PM
JoeC's Avatar
cool; I did what you described and got it to go straight on today; hooked it all back up and have everything tightened and now its drivable! No more rubbing even with large bumps at 40mph! wooo!
Though; my shifter pops out of 2nd, and 4th gear because of the shift boot being too high on the shifter without an extension, so I will need to weld that bar in if I want to solve that problem.
Old 09-28-2010, 12:10 AM
gary96360's Avatar
i didnt bother to extend the shifter, just bent theshifter foward and to the left a bit. had to do otherthings to make the transfercaselever work. butyou dont have that problem with a 2wd
Old 09-28-2010, 01:07 AM
JoeC's Avatar
my old welding teacher called me up the other day and told me to stop by and visit; so I was thinking what the hell.. its so easy to pull the shifter out of the truck; ill just bring it in with me and tig weld it up and throw it back in.
Old 09-29-2010, 12:46 AM
JoeC's Avatar
yeah; i had the firewall plate and mounted it; but i did need the extension at the steering box. all drivable now. Just gotta do the rear end.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: problems with body lift install
