Pressure in the gas tank?
Old Nov 25, 2007 | 05:58 AM
James Dean's Avatar
Does every else’s 2nd gen 4Runner develop allot of pressure in the tank. When I go to fill up, I have to let the air out slowly. It literally will blow the cap off if you remove it fast (not like a gun, but enough to make you drop it). I know all tanks have it, but I've had plenty of rides in my life and nothing like this. Does this sound like a problem or is it normal?
Old Nov 25, 2007 | 06:26 AM
nate V's Avatar
Yeah it is a prob
I would check your Charcoal Canister and see is its working properly.
Its the big cylinder on you pass side under the hood. Might need to replace that. Or your line might be clogged.
The Charcoal Canister receives the tank pressure vapors and incorporates it into your vacuum system.
Old Nov 25, 2007 | 07:42 AM
dirtyXplorer's Avatar
I have this same problem, even if I fill up on half. Mine almost sounds like suction but I am not sure. Is there any way to test the charcoal canister? Is there any bad side effects?
Old Nov 25, 2007 | 08:24 AM
longhungsilver's Avatar
there should be a bit of pressure (if the system hasnt just depressurized recently)...if its enough pressure to blow the cap out of your hand id say theres a definete EVAP problem. It should throw a code eventually tho i would think
Old Nov 25, 2007 | 08:28 AM
Tacoma750's Avatar
Mine does it to...Sounlds like someone let the air out of an air compressor when i take the gas cap off lol
Old Nov 25, 2007 | 08:43 AM
8yota9's Avatar
i second the air compresor lol
Old Nov 25, 2007 | 08:50 AM
fastkevman's Avatar
My '93 does it and seems to run very well, so I'm not worried about it.
Old Nov 25, 2007 | 09:18 AM
Bigblock's Avatar
All 3 of mine do it!
Old Nov 25, 2007 | 09:35 AM
Green93's Avatar
Mine does the vacuum thing too. The engine needs this vacuum to function properly. This is why you get a check engine light when the girlfriend doesn't turn the cap on tight enough. I always tell her...make it click a few times. She learned now since she had to take time out of shopping to go sit at the dealer while they tested it and reset the light.
If it blows out when you take the cap off then something is wrong somewhere.
Jason
Old Nov 25, 2007 | 10:37 AM
nate V's Avatar
Not sure if you can check the Charcoal Canister or how you do it but I would recommend that you look in haynes or chiltons manual...
I know that the newer cars and trucks run at a much higher tank pressure than the old ones do with early efi. So if it leeks it should throw a code depending on the year.
Old Nov 25, 2007 | 11:04 AM
89934runr's Avatar
tank venting
If your canister is jacked, I have one for ya. Your TVV cycles vacuum to the tank in order to burn the fumes- it might not be cycling, or your canister is blocked. Either that, or one of the check valves in the canister is blocked. You can blow it out using mid-pressure air (no more than 45psi). DO NOT use solvent in there- it will kill the charcoal inside.
What I'm getting to is that I THINK your tank isn't venting, so like any enclosed gasoline, it develops pressure- VERY dangerous is your in a dry part of the country (you'll wind up on the news / Youtube as 'that guy').
Easy to check!
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
pyramid
Jul 29, 2015 06:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
