power steering gear box adjustment screw
Old Jul 3, 2008 | 03:13 PM
Just Learning's Avatar
ok. im not sure if this is the right forum to place this , if im am misguided go a head and yell at me . but how do you tell if your gear box adjustment screw is proper what is back lash, also this has been replaced in 2006 it is leaking from the adjustment screw i have called auto stores amd no one nows how to solve it what is behind the dang nab thing a o ring i really dont know but the leak is really getting bad yes please help it is a 86 4x4 power steering
Old Jul 3, 2008 | 03:22 PM
abecedarian's Avatar
I've never had the need or inclination to take mine apart so I can't help you with the exact procedure or tell you what's in there. But when worse comes to worse, back the screw out and take careful note of how many turns it takes.
Also, if you go back to the main forum listing in this section of yotatech, there is a stick post linking to factory service manuals.
Old Jul 3, 2008 | 03:30 PM
dutchboy's Avatar
I don't know anything about the adjusment screw,but I can help solve your leak problem.
My power steering pump is leaking from the back side seal. I priced new PS pumps...w/o resivoir and their like $140 bucks...BUT...for $14.00, Advanced auto ordered me a PS pump seal rebuild kit. Gives ya all the seals for the job.
Now I just gotta get off my lazy ass,pull the pump out and get into it.
So....if you got the cash to replace the pump...again,go ahead. I strongly suggest,in my opinion,of replacing all the seals.
Old Jul 4, 2008 | 05:08 AM
dirtoyboy's Avatar
Just LEarning....what kinda fluid are you using in your box? If you are using power steering fluid that is probably what is creating your leak (especially since you said the box was just replaced in 2006)
Toyota FSM specifies AUTOMATIC TRANSMISSION FLUID ONLY in your steering system....
Old Jul 5, 2008 | 04:41 PM
iamsuperbleeder's Avatar
X's 2 on that... my pitman arm seal on my gearbox was dripping a bottle of PS fluid a month... got lazy and instead of replacing the box or even just the seal, I started using ATF... the leak has almost stopped now, lol.
mskalmus
May 28, 2017 07:51 AM
skoti89
Jul 8, 2015 12:05 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
