power doors keep unlocking??
Old 04-02-2016, 11:49 AM
mags's Avatar
Hello. So i am trying to unf*** all the electronic gremlins in my toyota. Today after installing a new battery and alternator, i attempted to lock my doors and every time i press lock, the doors will lock and then unlock 2 seconds later. This is with the truck on/off. I did this on both driver and passenger door. No clue how it happened. Any ideas?
1990 sr5 3.0 4x4 ifs
Old 04-02-2016, 12:07 PM
wyoming9's Avatar
Red face
This is with you in the truck and both doors closed ??
If I remember correct if you have the door open and don`t close it they will act just like you describe
It will also happen if one of the door switches is failing to open it appears like the door is open to the door lock relay.
Old 04-02-2016, 01:34 PM
mags's Avatar
Yes this is with doors opened or closed. Perhaps it is the switch failing. I haven't driven my truck in a month or so. Hence the new battery lol. Thanks for your input. I'll search around for a junked switch
Old 04-03-2016, 02:24 AM
wyoming9's Avatar
Red face
It can also be a broken wire
poor connection
after all the wires do go into the door opening and closing for 26 years does put wear on things.
Find out what is wrong before buying parts you might not need
Old 04-03-2016, 06:02 PM
RJR
RJR's Avatar
If the key is still in the ignition (or the truck thinks it is) it will do that.
Old 04-03-2016, 09:48 PM
SacRunner's Avatar
My 91 4Runner does this occasionally too; I know your frustration.
Key out of the ignition, hit the lock button, sometimes everything immediately unlocks; other times I shut the door and it immediately unlocks; other times yet, I hit the button, close the door "pretend to walk away" and they unlock a second or 2 later; then there are the times that everything just works as it should.
I know I should spend the 5-10 minutes to take the door panel off and watch the various components with a multi-meter to see what's happening, but it just hasn't been THAT big of an issue to me (it's been like this for the last 3-4 years for me).
If you figure out what it is, I'm certainly interested to hear more.
Old 08-30-2016, 08:00 PM
the78outlaw's Avatar
I recently purchased a 93 4Runner, and I'm having the same issue. My time is a premium , as I work 14 hours a day. Does anyone know of a couple of quick tests that I can do, with specific directions so I can maximize my available time when I troubleshoot this issue?
Old 08-30-2016, 09:00 PM
Charchee's Avatar
It's probably a bug in one of your switches either like the key in ignition safety or door switch but I do have a 4runner that's locks will act crazy when it's been raining for days on end. They lock, unlock, lock, lock, unlock etc. The truck stays damp inside when it's been out in the rain so I know I have a cab leak somewhere and I'm sure the moisture is getting to the lock controller. It will drain the battery while it's doing this. If I catch it doing it, I just pull the door lock fuse. You might perceive this issue as a random lock after a couple seconds but have you ever just stood still and watched it after you hear it do it the first time and see if it cycles the locks again after that? Does it do it more often when it's wet outside? I doubt you have the same thing going on, but just giving you something else to consider.
lbhsbz
04-02-2018 01:13 AM
Jrose
01-26-2016 01:39 PM
Aaron Brown
01-26-2016 05:16 AM
SwVa_1stGen
01-21-2016 04:05 AM
Fire4Effect
01-18-2016 12:25 PM
Quick Reply: power doors keep unlocking??
