parts interchangable? rear differential
Old 07-30-2005, 03:38 PM
brendonv's Avatar
I just bought a 1993 pickup, i want to take out my rear disks and differential out of my 1987 and put it in the new truck...could i just take the whole axle assembly out of the 1987 with the disks and just swap them with the 1993's axle assembly with the drums? I am pretty sure they are interchangeable but i just want to double check!
thanks
Old 07-30-2005, 04:56 PM
kyle_22r's Avatar
yep, should be pretty interchangeable. the spring perches are wider on the '93 axle and i *think* the springs may be as well, but you shouldn't have any problems(just use whatever spring plates/u-bolts that'll work)
Old 07-30-2005, 05:22 PM
brendonv's Avatar
im not talking about switching the housing, just the diff, and axle shafts with the bearings and stuff
Old 07-30-2005, 05:25 PM
Glenn's Avatar
Rear disk brakes? That wouldn't be stock on any '87 that I know of. Nor any stock Tacoma for that matter. Did you mean drums?
Old 07-30-2005, 05:26 PM
Yamaha+Toyota=Fun's Avatar
Yup, it will fit.
Old 07-30-2005, 06:02 PM
brendonv's Avatar
i put them on, allpro kit
Old 07-30-2005, 07:34 PM
kyle_22r's Avatar
oh, if you were referring to putting the third and shafts in the '93 housing, they'll most definitely fit.
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
msane99
07-11-2015 08:08 PM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: parts interchangable? rear differential
