Painting Box
Old 04-21-2008, 09:03 PM
olsy1984's Avatar
Painting Box
Well i'm about to get a new box for my truck, problem is, it is a different color. after learning how much it would cost to repaint the truck i think i will just try to paint mach the box with the cab. my idea is to paint the sides and the tailgate with a duplicolor paint mach and rhino line the inner bed. how well does duplicolor mach up?
thanks for any help
Old 04-21-2008, 09:21 PM
rowdy235's Avatar
why not go to a good parts store that sells paint? Get your paint code off the door or under the hood and get them to mix that paint. May be a bit more costly but it'll match. Now if the trucks been repainted thats another story
Old 04-21-2008, 09:49 PM
olsy1984's Avatar
it has been repainted before, but its stock color still i know for sure
Old 04-22-2008, 12:39 AM
olsy1984's Avatar
after trying to find my camera for a color reference which i couldn't find, i found this https://www.yotatech.com/forums/f86/...89-yota-97144/ looks to be the same color, the new box is silver however
Old 04-22-2008, 02:35 AM
rdlsz24's Avatar
I'm in a similiar situation as you:
I will be repainting the whole truck since it needs it and then I know it will match.
Rob
Old 04-22-2008, 03:35 AM
MMA_Alex's Avatar
you didnt mention what color it was. some colors are easier to match than others (like black). I'll second custom ordering the paint.
It goes on a lot smoother with a spray gun than with a spray can
Old 04-22-2008, 10:21 AM
olsy1984's Avatar
it's a light blue, i'm not sure the "Toyota name" for it. i may end up painting the whole thing, depending on costs
BTW: the new box which is mint, is only $500
Old 04-22-2008, 12:51 PM
MMA_Alex's Avatar
if you're interested in doing it yourself, and are willing to put the time into it you'd be surprised at how well it can come out
Old 04-22-2008, 12:54 PM
olsy1984's Avatar
i plan on spending a couple of weekends at my buddies garage sanding and preping, im really just hoping that the box and the cab mach...anyone have a guess as to how much paint i will need? i'm guessing 1 coat primer, 2 coats color, 1 coat clear?
Old 04-23-2008, 07:20 PM
highway's Avatar
some jobbers have a "gun" that can read the exact pigment of the paint and mix it accordingly. I did this type of match to my neighbors tacoma, it was white and never waxed and it was a perfect match.
Old 04-23-2008, 08:42 PM
standardbyker88's Avatar
i work in a paint and body shop. i know of the color you are talking about. its going to be a bitch to use duplicolor setup. might get close-ish. as for the matching theory. that would be alot closer. probably not dead on if you dont tint the color and blend it out onto the front of the truck a bit, but close. id say 1-2 coats of sealer to get it more neutral. then 3-4 coats of color, because that one is a bit thin. and 2-3 coats of clear to make sure their is enough to prevent uv protection for the basecoat.
but, you could also just repaint the whole truck so it all matches.
Jcrawl94
10
10-24-2015 04:34 PM
BeMiceElf
10-10-2015 09:40 PM
JookUpVandetti
09-11-2015 09:41 AM
58rennur4
08-04-2015 08:49 AM
Quick Reply: Painting Box
