Overheating in 22RE 3,000 miles after ENGBLDR FEK install
Old 01-04-2011, 08:34 AM
  #141
92 TOY's Avatar
the actual pipe
i believe it all becomes out of reach (maybe) with the manifold on.....my shield is is the way of my view, but if you can reach the small bolt that secures it to the block and the 3 that hold it to the back of the timing cover, you may just be able to pull it away enough...or totally, to service the end of it to be sure it's flat and clean.
Old 01-04-2011, 09:21 AM
  #142
Philbert's Avatar
Thanks Jerry! That's the one
When I get to it, I think I'll try removing the dizzy, PS pump, belts, and then remove that bolt that holds the pipe to the block....and then attack the 3 bolts on the flange.
Will report back when done
Old 01-04-2011, 09:24 AM
  #143
Philbert's Avatar
And Jerry....what on earth did you use to clean yoru parts? They look great....except for the block
Old 01-04-2011, 09:43 AM
  #144
92 TOY's Avatar
I never touched the block.
I used "orange goop" hand cleaner from Harbor Freight to clean everything....rinses clean, no residue like all the others.......everything I touched, I cleaned and painted 9for the most part).....couldn't stand looking in there and trying to differentiate black from gray from grayish black.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Overheating in 22RE 3,000 miles after ENGBLDR FEK install
